2015 TBS New Release Presentation:TBS6908/TBS6983/TBS7720/TBS2216
Description:
TBS6908 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6908 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also CCM, ACM, VCM, Multi Input Stream, 16APSK,32APSK,Generic Stream Mode , which most satellite receiving devices can’t support. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are ready.
TBS6908 Professional DVB-S2 Quad Tuner PCIe Card, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream, 16APSK,32APSK or Generic Stream Mode.
Main Features:
Quad tuner DVB-S2/S transponders receiving
CCM, VCM, ACM and Multi Input Stream support
Generic stream mode Support
Up to 190 Mbit/s channel bit rate capture
Wide range symbol rates support from 1Msps to 45Msps
High-speed data download via satellite
Unicable/one cable compatible
Blindscan
High reliability
Applications:
Satellite feed hunt
Satellite data download
Lock of special transponders
Specifications:
Receiving frequency: 950~2150 MHz tuning range
Input level: -69~-23dBm
Quad channels DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK ACM/VCM Demodulator
Symbol rate:
-Maximum symbol DVB-S2 rate limitations (Msymb/s)
Msymb/s Demod LDPC Single Dual
QPSK 67.5 135 67.5 67.5
8PQSK 67.5 90 67.5 45
16APSK 67.5 67.5 67.5 33.7
32APSK 67.5 54 54 27
-DVB-S
QPSK+1/2, 2/3, 3/4, 5/6, 7/8
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Power consumption: 0.66W ~ 33.13W
TV tuner card size: 145mm*92mm (Length x Height)
System Requirements:
Windows XP / Vista/ 7/8, Linux
Pentium 4 2.0 GHz, Pentium M 1.3 GHz
For HDTV: 2.6 GHz multi core processor
Hard disk with min. 1 GB free capacity
Sound and graphics card with support for DirectX 9 or higher
Available PCI Express x1, x4, x8 or x16 slot
CD/DVD drive for software installation
Package Contents:
1 x TBS6908 Professional DVB-S2 Quad Tuner PCIe Card
1x Power cable
1 x Software CD
Description:
TBS6983 is a Professional level digital satellite TV Tuner card with PCI Express interface. TBS6983 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also CCM, ACM, VCM, Multi Input Stream, 16APSK,32APSK,Generic Stream Mode, which most satellite receiving devices can’t support. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are ready.
TBS6983 Professional DVB-S2 Dual Tuner PCIe Card, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream, 16APSK,32APSK or Generic Stream Mode. The built in hardware blind can feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. Such blind scan feature can be achieved by dedicated TBS tool.
Main Features:
Blindscan
High reliability
Applications:
Satellite feed hunt
Specifications:
Dual channels DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK ACM/VCM
Demodulator
Symbol rate:
-DVB-S QPSK+1/2, 2/3, 3/4, 5/6, 7/8
Package Contents:
1 x TBS6983 Professional DVB-S2 Dual Tuner PCIe Card
1 x remote control
1 x IR receiver
1 x power cable
1 x Software CD
Description:
TBS2216 HD HDMI encoder is a professional high-definition video coding box, which equipped with 1 HDMI channel input and dual stream RJ45 output. TBS2216 supports MPEG-4 AVC/H.264 High Profile code format input and dual stream H.264 format, audio ACC format output.
TBS2216 HD HDMI encoder can be widely used to bellow applications:
1. IPTV;
2. Digital Signage;
3. Video Conference;
4. Replace HD Video Capture Card;
5. Hotel TV system;
6. Live Broadcast;
7. Teaching/Campus Broadcast;
8. Recording System;
9. NVR (Net Video Recorder);
Specification:
Video:
Input: 1x HDMI (1.3a);
HDMI Resolution: 1920×1080_60i/60P, 1920×1080_50i, 1280×720_60p, 1280×720_50p and below;
Encoding: H.264/AVC Main Profile/High Profile ,Audio AAC;
Data Rate: 0.8Mbps~12Mbps;
Rate Control: CBR/VBR;
GOP Structure: IBBP;
Advanced Pretreatment: De-interlacing, Noise Reduction, Sharpening.
Audio:
Encoding: AAC, MP3;
Sampling rate: Auto;
Bit-rate: 32K/48K/64K/96K/128K/160K/192K;
Sampling precision: 24 bit;
Data Rate: 64Kb/s ~ 384Kb/s;
System:
Ethernet/RJ45: 1000 Base-T Ethernet interface;
Protocol: HTTP,UTP,RTSP,RTMP,ONVIF;
Control Interface: WEB;
General Spec:
Weight: 0.5kg
Working Temperature: 0~45℃
Packing List:
1. TBS2216 HDMI Video Encoder *1PCS
2. Power DC12V *1PCS
3. Giftbox *1PCS
Description:
TBS 7220 DVB-T2/T/C TV Tuner mini PCIe Card, is a digital terrestrial tuner card with DVB-C function added, which allows you to enjoy free-to-air (FTA) digital terrestrial/ cable TV and digital stereo radio on PC. TBS 7220 can be used as a digital video recorder for recording digital terrestrial/cable TV programs with full HDTV support. It also enables you to pause a live broadcast and continue from where you left with the Time-shifting function. This DVB T2/T/C PC TV card is ready with windows BDA driver and Linux driver. It's ideal for watching UK Freeview SD and HD channels on your PC.
Please ensure you can receive the Digital Terrestrial Television (DVB-T, DVB-T2, Freeview) service in your region. The TBS 7220 requires you use a high-gain roof aerial to enable and enjoy reliable Digital Television reception throughout the UK.
Main Features:
Watch free-to-air digital terrestrial TV on PC
DVB-T2, DVB-T and DVB-C are supported
High-definition video, real-time and scheduled video recording
High sensitivity tuner for the best digital TV reception
Specifications:
Card dimension: 50.95* 30mm
• DVB-T2/T2 Lite (V1.3.1)/T
DVB-T2/T Receiving Channel: VHF band and UHF band
Channel Bandwidth: 6, 7, 8 MHz
DVB-T2/ T modulation type: QPSK, 16QAM, 64QAM, 256QAM
FFT mode: 1K, 2K, 4K, 8K, 16K, 32K
Code rate: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 7/8
Guard interval: 1/4, 1/8, 1/16, 1/32, 1/64, 1/128, 19/128, 19/256
Intermediate frequency:
IF mode: Low IF
Center IF Frequency: 3 ~ 5 MHz
Note: default 4MHz
• DVB-C
Fully compliant with DVB-C and ITU J83 A/B/C specifications
Receiving Frequency: 47~862 MHz tuning range
Input level: -65~-10dBm
16QAM, 32QAM, 64QAM, 128QAM and 256QAM support
Symbol Rate: 0.87 to 9Mbaud
Available mini PCIe slot
Package Contents:
1 x TBS7220 DVB-T2/T/C TV Tuner mini PCIe Card
1x RF extension cable
