Vu+zero
Affordable DVB-S2 HD Zapper
There was one goal in developing ZERO from the beginning. Let’s make something more affordable to please more Vu+ fans. As the name suggests, the end user price of ZERO is remarkably competitive while maintaining the performance and philosophy of Vu+ products. Zero is the most affordable DVB-S2 HD Zapper of Vu+ ever.
Powerful Features
It was certainly a challenging task to increase the affordability while not losing the performance that Vu+ pursues. So, ZERO comes with a 2000 DMIPS CPU powerful enough to support all demanding multimedia functions. Despite of its compact and slim design, all important connectors are nicely equipped as below:
Slim & Elegant Design
ZERO characterizes the design philosophy of Vu+. Its elegant external design is stunningly standing out among those monotonous and tasteless set top boxes in the market. ZERO’s beauty deserves to be placed right next to your TV. ZERO comes in black and white.
Produktbeschreibung
Digitaler Receiver fur HDTV- und Radioprogramme.
Hauptmerkmal ist der 2K DMIPS starke Prozessor des VU+ ZERO. Erleben Sie HighDefinition TV mit Ihrem VU+ ZERO.
•Opera Browser
•HbbTV
•HDMI 1.4 Anschluss
•DVB-S2 Tuner
•Externes 12 V Netzteil
Technische Highlights:
•2K DMIPS Prozessor
•DVB-S2 Tuner
•256MB Flash
•512 MB DDR3 DRAM
•1 x Smartcard-Reader (Xcrypt)
•2 x USB
•10/100 MBit Ethernet Interface
•1 x HDMI 1.4 Video/Audio Ausgang (digital)
•1 x Video Ausgang RCA (analog)
•2 x Audio Ausgang (L/R) RCA (analog)
•unlimitierte Kanalliste fur TV/Radio
•EPG (electronic program guide) Unterstutzung
•Unterstutzung von Favoriten-Listen (Bouquets)
•OSD in vielen Sprachen und Skin-Unterstutzung
•erweiterbar durch Plugins
•automatischer /manueller Kanalsuchlauf
•DiSEqC 1.0/1.1/1.2, USALS
•Externes 12 Volt Netzteil
•Netzschalter
VU+ ZERO Technische Daten:
•DVB-S2 Tuner:
•Eingangsfrequenzbereich 950...2150 MHz
•Eingangspegelbereich - 65 dBm...- 25 dBm
•Tuner Eingang F-Buchse
•Eingangsimpedanz 75 Ohm
•AFC-Fangbereich +/- 3,5 MHz
•Demodulation QPSK und 8PSK
•FEC Viterbi und Reed-Solomon
•Viterbiraten 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
•Roll-off Factor 35 %
Videodekodierung:
•Videokompression MPEG-2 / H.264 und MPEG-1 kompatibel
•Videostandard PAL G/ 25 Hz, NTSC
•Bildformat 4:3 / 16:9
•Letterbox fur 4:3 TV-Geräte
Ausgang Analog:
•Ausgangspegel L/R 0,5 Vss an 600 Ohm
•THD > 60 dB (1 kHz)
•Übersprechen < -65 dB
Video-Parameter:
•Eingangspegel FBAS 1 Vss +/- 0.25 dB an 75 Ohm
Ethernet:
•100/10 MBit kompatibles Interface
USB:
•USB 2.0 Anschluss (2x)
LNB Stromversorgung DVB-S2 Tuner:
•LNB Strom 400mA max. , kurzschlussfest
•LNB Spannung horizontal ohne Last 19,5V17,6V bei 400mA
•LNB Spannung vertikal ohne Last 14,5V 11,8V bei 400mA
•LNB wird im Standby-Modus abgeschaltet
Steuerung der Satellitenpositionen:
•DiSEqC 1.0/1.1/1.2 und USALS - Rotor Steuerung
Leistungsaufnahme:
•< 13W (im Betrieb, mit LNB)
•< 12W (im Betrieb, ohne LNB)
•< 0,5W (Deep-Standby-Mode)
Eingangsspannung:
•Externes Netzteil:
•Eingang:
•110-240V AC / 50-60Hz / 1,0A
•Ausgang:
•12V = / 3,5A
Allgemeines:
•Umgebungstemperatur +15°C...+35°C
•Luftfeuchtigkeit < 80%
•Abmessungen (B x T x H): 211 mm x 185 mm x 40 mm
Lieferumfang:
•Receiver ( VU+ ZERO )
•Fernbedienung
•Batterien
•Kabel fur analoge A/V Ausgänge (3,5 mm Klinke)
•externer IR Sensor
•externes Netzteil
•Bedienungsanleitung
