Setare Phoenix/Smartmouse in CCcam.cfg
buna ziua,
server CCcam Ubuntu, card Focus citit cu Smargo.Se doreste citirea cardului cu Phoenix/Smartmouse pe USB .
Ce editari ar trebui facute in CCcam.cfg pentru Phoenix/Smartmouse pe USB ?
Multumesc
Mai jos e CCcam.cfg-ul actual care merge OK cu Smargo.
#CCcam.cfg#
SERVER LISTEN PORT : 12000
ALLOW TELNETINFO: no
ALLOW WEBINFO: yes
WEBINFO USERNAME : user
WEBINFO PASSWORD : pass
#TELNETINFO USERNAME :
#TELNETINFO PASSWORD :
#TELNETINFO LISTEN PORT : 18000
WEBINFO LISTEN PORT : 16001
ZAP OSD TIME : 0
OSD USERNAME : root
OSD PASSWORD : ####
OSD PORT : 80
SHOW TIMING : yes
DEBUG : no
NEWCAMD CONF : no
DISABLE EMM : yes
EXTRA EMM LEVEL : yes
MINI OSD : yes
#SOFTKEY FILE : /var/keys/SoftCam.Key
#AUTOROLL FILE : /var/keys/AutoRoll.Key
#STATIC CW FILE : /var/keys/constant.cw
CAID PRIO FILE : /var/keys/CCcam.prio
LOADBALANCE : /dev/ttyUSB0
LOADBALANCE : /dev/ttyUSB1
SERIAL READER : /dev/ttyUSB0 smartreader+
SERIAL READER : /dev/ttyUSB1 smartreader+
SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 3570000
SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB1 3570000
PIN: /dev/ttyUSB0 1234
PIN: /dev/ttyUSB1 1234
MINIMUM CLIENT VERSION : 2.0.1
EMM THREADS : 2
MINIMUM DOWNHOPS: 0
---------- Post added at 08:41 ---------- Previous post was at 08:31 ----------
am gasit aici ceva [Only registered and activated users can see links. Click Here To Register...]
sper sa-mi fie de folos.
