receiver HD la cel mai bun raport calitate-pret
Ceau.Puteti sa-mi spuneti daca am vreo sansa sa gasesc un receiver hd la un pret ok?ok-pana in 300 RON.Am citit un review ok despre Alma S2100 cum ca ar fi superok si pt canale cu emisie slaba.Cam asta stie sa faca:
- Full HD Digital Satellite Receiver
- Conax Embedded card reader
- DiSEqC 1.0, 1.2 and USALS compatible
- Dolby Digital BitStream out via S/PDIF & HDMI
- Channel Recording to External Storage Devices
- TimeShift Support
- MKV, AVI, MPG, MOV, MP3 playback support
- Automatic Install function
- 4 (7 segment) digit LED display
- Powerful Channel Management tools (Lock, Edit, Move, Skip, Delete)
- Favourites
- User Friendly On-Screen Display (OSD)
- Multi-Language support
- Subtitles support (DVB/TXT)
- Software Upgrade Support via USB & RS232
- <1W Power Consumption in Stand-By mode
System standard: Fully MPEGII/DVB Compliant
Input Frequency: 950~2150Mhz
RF Input level: -65~-25dBm
LNB Control: DiSEqC1.0/1.2
LNB Power:13V/18V (Max, 400mA)
LNB tone switch: 22KHZ
Waveform: 8PSK / QPSK (SCPC, MCPC capable)
Symbol rate: 2~90Msps |
Video format: MPEG-II Main prole/Main level
Audio format: MPEG-II layer I&II
Aspect Ratio: 16:9, 4:3
Audio sampling rate: 32,44.1, 48kHz
Audio Type: Left / Right / Stereo / Mono
Graphic display: 1920×1080, 1280×720, 720x480 |
Processor: 400MHz based CPU
RAM: 128Mb DDR
FLASH: 8 Mb |
Supply Voltage: Free Voltage (175~250V AC, 50/60Hz)
Supply Power: Max.30 W
Stand-By Power: <1W
Operating temp: 0°C~40°C |
Display: 4Digit (7-segment) LED display
Dimensions: 260(W) x 150(D) x 45(H)mm |
Satellite IF input: F-type (Digital)
Satellite IF loop out: 950-2150MHz
1 SCART TV (RGB, CVBS)
RCA/Composite Audio Left & Audio Right
0/12V Output
RS232: 9 way D RS232 DCE serial port
S/PDIF: Coaxial
HDMI
USB |
Daca nu vreau sa vad decat canalele fta SD si HD,e o alegere buna?
