TBS5925 USB DVB-S2 Professional TV Box
Description:
TBS5925 USB DVB-S2 Professional external TV Tuner box, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream(MIS), 16APSK, 32APSK, which most satellite receiving devices can’t support. The built in hardware blind scan feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. With use of dedicated TBS tools or Crazyscan, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are provided.
TBS5925 is the USB version of its’ equivalent device: TBS6925 PCIe DVB-S2 Professional TV Tuner card
Main Feature:
DVB-S2/S Transponders Receiving
CCM, VCM,ACM and Multi Input Stream Support
Wide range symbol rates support from 200Ksps to 45Msps
High-speed Data download via Satellite
Unicable/One Cable compatible
Blindscan
High reliability
Applications:
Satellite feed hunt
Satellite Data download
Lock of special transponders
Specification:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK Demodulator
Symbol Rate:
DVB-S QPSK 0.2~45Msps
DVB-S2 QPSK/8PSK 0.2~45Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10
16PSK Puncture codes: 2/3,3/4,4/5,5/6,8/9,9/10
32PSK Puncture codes: 3/4,4/5,5/6,8/9,9/10
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
TV Box Size: 78x64x26mm (Length x Width x Height)
TV Box Weight: 137 Gram
Package Gift Box Size: 200x162x55mm (Length x Width x Height)
Package Gift Box Weight: 647 Gram
System Requirements:
Windows 2000/XP/Vista/7 or Linux
DirectX9.0 or later Version
Available USB2.0 Port
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Graphic Card with at Least 64MB RAM
Package Content:
1 x TBS5925 USB DVB-S2 TV Box
1 x remote control
1 x Power Adapter
1 x USB Cable
1 x Software CD
TBS 5925 now implemented on Enigma2/mipsel receivers
We are happy to announce that in our SatDreamGr images we have managed to finally incorporate support for TBS tuners, especially TBS5925 and TBS5980 using Crazycat's work as a base.
After a long period of testing, the first receiver fully scanning all Multistream channels and ACM/VCM 16APSK/32APSK channels as well is Edision OSmini. Soon enough we will extend functionality to all receivers we support that run in kernels higher than 3.8.
So far, scanning and zapping through MIS is seamless and very fast. We are working hard to also implement blindscan features and investigate direct T2-MI encapsulation.
Our patches will be available soon in openPLI (on which SatDreamGr images is based) with hope that more developers/coders will create new plugins such as Crazyscan for Enigma2 to extend these cards' capabilities.
Here is a video which demonstrates scanning and zapping on my own OSmini receiver.
Thanks to glamourservices for this info
hxxp://www.satdreamgr.com/forum/cmps_index.php?pageid=satdreamgr-images&tabid=577
Multistream reception on 5W using TBS5925 on Enigma2 SDG image OSmini
your xml file:
