Distorted judder on HD Channels
Hi all,
For some time now we have had a problem with some HD channels on sat position 28.2. If you watch a channel after about 5 minutes the video becomes distorted. To explain it better, if you are watching golf and the player hits the ball you can see the ball with 3 other balls behind like a trail, its the same for football. If you switch channel and go back again it is ok for 5 minited then it happens again. If you use spark OS it will not happen only enigma 2 and neutrino. When the add break comes on it does not happen.
We have tried all video setting and also tried changing things via telnet.
At this point it looks like it is the pti drivers as spark dont use them and all is ok with spark.
Any help or suggestions would be appreciated. :)
