Black Hole Vu+ Uno v. 2.0.4
Black Hole 2.0.4
- New: Subtitle Auto Language Support
- New Skin: MX S Line by Matrix10
- New: Vfd skin by Ev0 (duo2)
- Custom updated version of lcd4linux (duo2)
- TranscodingSetup : add bitrate/framerate support (duo2)
- Update Hbbtv and opera browser
- New Vu+ drivers 20130703(duo2)
- Support transcoding bit/frame rate change(100K< bitrate< 5M, framerate=23976 24000 29970 30000 59940 60000 )- Enable SD video when transcoding
- New Vu+ drivers 20130621(all):
- Fix TS Playback problem
- Fix i2c error handling
- Turn off LCD at standby by default(duo2)
- Change default LCD brightness(duo2)
- Support DVB-T external antennae(duo2)
fixed to be used the rc-keyboard at duo2.
vuplus homepage url changed www2.vuplus.com -> vuplus.com
remove the uri log when playing the vod
NetworkWizard : remove confdns for inet static.
Adjust kernel config (duo2)
added libcec
gstreamer_0.10.36.1.bb: fixed "GStreamer-CRITICAL
opkg: some fixes/changes for handling packet recommends
busybox: passwd use SHA512 by default
busybox: mount: don't pass option auto to kernel
do sync after umountfs
gst-plugins-good : remove gtk+ on DEPENDS
make RDEPENDS of package specific
dbus-1.4.16: fix compile with c++11
update python-coherence
update OpenWebIf
update languages: fr cs fr sv sk
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to Littlesat and Pli Team for the original autolanguage selection code
DISCLAIMER
LICENSE (TERM OF USE)
