Alma S -2250
salut ! am achizitionat acest receiver HD alma s-2250
m-ar interesa daca stiti sau a-ti avut probleme cu el
am inteles ca ar fi si wirelles dar vad ca optiunea e inactiva
stiti de unde se poate activa ?
Sau se refera la faptul ca merge cu wirelles pe usb . Mulumesc !
---------- Post added at 21:21 ---------- Previous post was at 21:07 ----------
Full HD Digital Satellite Receiver
Compact Design
Conax Embedded card reader
Ethernet Connection & WiFi Support
YouTube Support
External IR Receiver
Weather Forecast & RSS Reader Functions
DiSEqC 1.0, 1.2 and USALS compatible
Dolby Digital BitStream out via HDMI
Channel Recording to External Storage Devices
TimeShift Support
MKV, AVI, MPG, MOV, MP3 playback support
Powerful Channel Management tools (Lock, Edit, Move, Skip, Delete)
Favourites
User Friendly On-Screen Display (OSD)
Multi-Language support
Subtitles support (DVB/TXT)
Software Upgrade Support via USB & RS232
TECHNICAL SPECIFICATIONS
Tuner & Demodulation
System standard: Fully MPEGII/DVB Compliant
Input Frequency: 950~2150Mhz
RF Input level: -65~-25dBm
LNB Control: DiSEqC1.0/1.2
LNB Power:13V/18V (Max, 400mA)
LNB tone switch: 22KHZ
Waveform: 8PSK / QPSK (SCPC, MCPC capable)
Symbol rate: 2~90Msps
A/V Mode
Video format: MPEG-II Main prole/Main level
Audio format: MPEG-II layer I&II
Aspect Ratio: 16:9, 4:3
Audio sampling rate: 32,44.1, 48kHz
Audio Type: Left / Right / Stereo / Mono
Graphic display: 1920×1080, 1280×720, 720x480
Microprocessor & Memories
Processor: 400MHz based CPU
RAM: 128Mb DDR
FLASH: 8 Mb
Power & Environment Condition
Supply Voltage: DC 12V
Supply Power: Max. 20W
Operating temp: 0°C~40°C
Physical Specification
Dimensions: 108(W) x 70(D) x 18(H)mm
Net. weight: 0.12Kg
Connectors
Satellite IF input: F-type (Digital)
USB: High Speed USB2.0
Ethernet: RJ45
RS232: 3.5mm Jack Type
IR: 3.5mm Jack Type
HDMI
USB
DC IN: 12V
Se refera la faptul ca merge cu wirelles pe usb.
