How to update Vu+ images
To install a new image, you need an empty USB stick FAT32 formatted.
Download image zip file for your Vu+ model;
Unzip the zip file and you will have a folder named vuplus and under the folder, you will have another folder named after the model of your VuPlus set;
Copy the vuplus folder (including all the sub folders and files in it) to root folder of your USB stick;
If you have any folder named vuplus on any device connected to your Vu+, delete the folder or rename it;
Turn off your Vu+;
Insert the USB stick to the front USB port on the set;
Turn on your Vu+.
Vu+Duo
Update is done when upgrade completed message is shown on the display.
Vu+Solo
Update is done when green light blinks on the front panel.
Vu+Solo2
Push POWER button on the box (not on remote) when message appears on display.
Vu+Uno
Push CH+ button on the box (not on remote) when message appears on display.
Vu+Ultimo
Push - button on the box (not on remote) when message appears on display.
If, for any reason, the upgrade fails, first disconnect any USB devices connected to your Vu+ and try again to install the new image.
If the upgrade fails again, try to use another USB stick.
sursa - vuplus-community
