Passwd: sateliti.info
Noutati in setari...chiar face treba foarte bine inclusiv cu "ndS"
UNICAM V3.1 - Configuration file
{{ unicam.conf }}
[global]
debuglevel = {bitmap}
0x01 1 Log softcam CaPMT
0x02 2 Log softcam ECM
0x04 4 Log softcam EMM
0x08 8 Log network
0x10 16 Log reader input / output
0x20 32 Log ECM/EMM timing
0x40 64 Log authentication info
0x80 128 Log CA system
0x100 256 Log internal message
0x200 512 Log memory
0x400 1024 Log debug/test
1
.... (critical error and boot are always logged)
{ for example, to log network and softcam ECM do sum
between 2 and 8 and specify numer 10 }
logfile = { ex. /var/log/unicam.log }
{ ex. mysyslogserver.com,port }
{ leave blank for stdout }
nodeid = { nodeid, if blank is random set at boot
ex. 309fa201b40091d0 }
accounttvf = { default filter for all accounts, see filter syntax }
readertvf = { default filter for all readers, see filter syntax }
traceconf = { ex. /var/log/unicam_conf.log
useful to trace configuration changes via web interface }
[softcam]
enabled = 0 | 1
processemm = 0 | 1
maxemmhop = { maxium hop of cards affected by EMM, default 0
only local cards }
waitlocal = { number of seconds to wait local reader be ready }
2
[webserver]
enabled = 0 | 1
port = { ex. 8080 }
username = { user name for web authentication }
password = { password for web authentication }
[reader]
enabled = 0 | 1
label = { es. remote1 }
protocol = newcamd | cccam | sci | smargo | scard | emu | ccw | pcsc | phoenix | nxp | fake
key = { ex. 00010203040506070809AABBCCDD }
keyfile = { ex. /var/keys/Card.Key }
{ support file for load keys used in CW decrypt, for example
Viaccess D2 ecm-tag; the file syntax is the same of
SoftCam.Key }
account = { ex. login,password }
wantemu = 0 | 1
{ request to remote emulated cards too }
3
ignoreua = 0 | 1
{ ignore remote UA received by reader }
device = { ex. myserver.com,port }
{ ex. /dev/sci0 }
{ ex. /var/keys/SoftCam.Key }
{ ex. /var/keys/constant.cw }
mhz = { ex. 357, 400, 600 }
reboot = hh:mm
{ daily reboot of reader at specified time, ex. 03:00 }
fakedata = { CAID (len 4), PROVID (len 6), UA (len 8) }
{ ex. 09CD,000000,0000000001FF01BA }
activation = { ex. 00112233445566778899aabbccddeeff }
{ any server will be activated only if a local card is present
and allowed by this activation key; exists two type of
activation local and full; in local mode unica allow
a maximum of 5 connection from private IP classess
10.0.0.0/8, 192.168.0.0/16 and 172.16.0.0/12;
be aware that unicam does not like payserver }
boxid = { ex. 0A0B0C0D }
4
{ ex. 0A0B0C0D,1B2C3D some CA systems allow to specify IRD
model with additional bytes }
marryinfo = { ex. 0000000000000000000000000000000000010002030002020203 }
software = { to emulate some specific software }
{ ** CCcam ** }
{ ex. 2.0.5,1654 }
{ ex. 2.0.7,1943 }
{ ex. 2.0.8,2699 }
{ ex. 2.0.9,2816 }
{ ex. 2.0.11,2892 }
{ ex. 2.1.0,2944 }
{ ex. 2.1.1,2971 }
{ ex. 2.1.2,3094 }
{ ex. 2.1.3,3165 }
{ ex. 2.1.4,3191 }
{ ex. 2.2.0,3290 }
{ ex. 2.2.1,3316 }
{ ex. 2.3.0,3367 }
{ ** newcamd stealth mode (first two chars are taken) ** }
5
{ ex. mgcamd }
{ ex. evocamd }
{ ex. CCcam }
processemm = { bitmap }
0x01 1 All UA
0x02 2 Group UA
0x04 4 Unique UA
emmcache = 0 | 1
{ useful to disable EMM cache in case of remote reader, default 1 }
emlog = ecm | emm | all | no
emlogfile = { ex. /var/log/cardemm.log }
emlogsb = { comma separated list of status bytes to log }
{ ex. emlogsb= 9021,9AA1,9821,9800,9801,91A0,90A0,90A1 }
ecmlogfilter = all | sb | nsb | no
{ ex. sb }
{ controls which ECM will be logged
sb indicates to log only that match status bytes,
nsb log only that does not match, default no }
emmlogfilter = all | sb | nsb | no
6
{ ex. sb,no,all }
{ controls which EMM will be logged for global/all, shared/group and unique,
nsb log only that does not match, default no,no,all }
emmmaildir = { ex. /var/log/cardemail <-- must be a directory }
{ some system send e-mail to cards, here will be stored each TXT
received }
emmfilter = { if empty all EMM are sent to the card, otherwise will pass only that
are allowed by filter; syntax is CA dependent; each type is separated
by a comma; if type is prefixed by ! check is inverted }
{ ex. 02,07,!03 }
emmflood = { ex. 5000,1000,0 }
{ time flood for EMM global/all, shared/group and unique in milliseconds,
EMM which exceed flood will be considered as spam }
tvfilter = { see filter syntax }
timeout = { CW timeout, default 2000 ms }
flags = { to enable specific CA functions / fix }
{ ** Viaccess ** }
{ emu18 to emulate tiers update INS after receiving a valid
7
signature }
{ ** Videoguard 2 ** }
{ cwf25 to enable fetching of CW from D354 response in TAG 25,
useful to fix 9993 error in some cards }
{ algck to check EMM algo info }
{ query continous query of card status }
{ tschk check timestamp of ECM/EMM }
balancing = x:y
{ ex. 1:2
if you have two or more equivalent card, you can specify a balancing
value that represents the number of cards; "x" is the number of the card
between the equivalents, "y" is the total of the cards
for two equal card insert 1:2 and 2:2, for three insert 1:3, 2:3 and 3:3
and so on... the cards are served to the clients in round-robin mode,
working on differents hops }
[server]
enabled = 0 | 1
label = { ex. newcamd1}
8
protocol = newcamd | cccam | directio
port = { ex. 17900 }
reader = { specify label of associate reader in newcamd protocol, if
none is specified newcamd goes in CWS mode }
antisniff = 0 | 1
{ for certain protocol insert random and unpredictable send to
client to make more difficult network sniffing }
minbuild = { ex. 3316 }
{ reject client with software build number lesser than this }
[account]
enabled = 0 | 1
user = { ex. mylogin }
pwd = { ex. mypassword }
sendemm = 0 | 1
9
ipfilter = { ex. 192.168.1.1, specify more IP adding several ipfilter lines }
{ ex. 192.168.1.0/24, allow connection from all subnet }
viewua = 0 | 1 | 2
0 (default) the client does not see hex serial of cards
1 the client see real hex serial
2 fake hex serial is sent to the client
forcedelay = { ex. 200, force a delay time between an ECM and the next one,
to discourage excessive reshare by the peer }
limitlogin = { ex. maximum number of connection allowed with the same user,
default is 1 }
{{ TV filter syntax }}
Filter syntax is similar to the Linux iptables one.
Allowed keywords:
D = allow | deny
{ default policy }
J = allow | deny
{ policy of rule }
10
C = { caid hex, ex. 093B }
P = { provid hex, ex. 5411 }
H = { maximum hop of the card, ex. 3 }
F = { filter for reshare, ex. 1 }
W = { level of reshare for account, forced reshare for readers, ex. 1 }
A = { hop added to cards (in share), maximum 10, ex. 2 }
B = { hop added to cards (always), maximum 10, ex. 2 }
S = { sid hex, ex. 0FE7 }
Example to deny all card to an user, except 0500/020830 and 093B,
the first served by a card with maximum 3 hops, the second with a max down
of 1 (no reshare), general max down of 2:
tvfilter= D:deny W:2
tvfilter= J:allow C:0500 P:020830 H:3
tvfilter= J:allow C:093B W:1
{{ unicam.srvid }}
11
The file contains channels list.
093B:000000:0FE7 "Sky Italia - Eurosport HD [NDS3]"
093B:000000:24E6 "Sky Italia - Fox News [NDS3]"
093B:000000:24E7 "Sky Italia - Cultoon [NDS3]"
093B:000000:2500 "Sky Italia - Boomerang [NDS3]"
093B:000000:2501 "Sky Italia - Hallmark Italia [NDS3]"
093B:000000:2503 "Sky Italia - Jetix +1 Italia [NDS3]"
093B:000000:2504 "Sky Italia - Cartoon Network +1 [NDS3]"
093B:000000:2505 "Sky Italia - MGM Italia [NDS3]"
093B:000000:2506 "Sky Italia - Roma Channel [NDS3]"
093B:000000:2507 "Sky Italia - Boomerang +1 [NDS3]"
093B:000000:2C27 "Sky Italia - Sport Italia [NDS3]"
093B:000000:2C28 "Sky Italia - Deejay TV [NDS3]"
{{ unicam.tiers }}
The file contains card tiers description.
12
0500:023800:0001:RSI LA 1
093B:000000:0226:Mondo
093B:000000:021B:Cinema
093B:000000:0228:Sport
093B:000000:0295:Calcio
093B:000000:0296:Ticket Serie B
0919:000000:0219:Mondo HD
13
UNICAM V3.1 - Changelog
1008 2013.02.01 VG2 improvement
Sci Protocol improvement
Nagra Rev 9xx Supported
1004 2013.01.29 Webif improvement
1000 2013.01.26 Improvement error prevention 999x
0990 2013.01.15 Jquery UI custom Update to v1.10.0
0989 2013.01.15 Webif Jquery Update to v1.9.0
0987 2013.01.14 Minor Bugfix
0983 2012.12.01 Videoguard improvement
0977 2012.11.24 Jquery UI custom Update to v1.9.2
0970 2012.11.18 Videoguard improvement
0962 2012.11.14 Webif Jquery Update to v1.8.3
0927 2012.10.26 Jquery UI custom Update to v1.9.1
0924 2012.10.22 Videoguard improvement
0917 2012.10.08 Jquery UI custom Update to v1.9.0
0914 2012.09.29 New Libusb Protocol
14
0913 2012.09.23 New Fake Reader Protocol
0908 2012.09.21 Webif Jquery Update to v1.8.2
0907 2012.09.14 Smargo Protocol Improvement
0902 2012.09.10 Webif improvement
error prevention 999x improvement
Other Fix
0898 2012.09.09 Videoguard improvement
Webif improvement
0883 2012.09.05 Webif Fix
Add error prevention 999x
0876 2012.09.02 New DirectIO server protocol
Unicam Studio for Windows
Ecm/Emm Log improvement
Webif improvement
0866 2012.08.31 Webif Send Area Check Parsing improvement
Webif Jquery Update to v1.8.1
Viaccess improvement
0864 2012.08.30 Videoguard improvement
15
Webif improvement
0863 2012.08.25 Webif improvement
0862 2012.08.23 Webif improvement
New setting minbuild in [Server]
0860 2012.08.16 Jquery UI custom Update to v1.8.23
0859 2012.08.10 Webif Jquery Update to v1.8.0
Webif Fix
0857 2012.08.09 Jquery Booklet Update to v1.4.0
Webif Fix
0855 2012.08.08 Webserver Fix
0854 2012.08.01 Improved webif
0853 2012.07.26 Jquery UI custom Update to v1.8.22
0852 2012.07.06 Support for Enigma 2 (OE 2.0)
0851 2012.07.05 Improved Softcam
0850 2012.06.21 Improved webif
0849 2012.06.07 Jquery UI custom Update to v1.8.21
0848 2012.05.11 Improved webif
0847 2012.05.06 Minor fixes
0844 2012.05.06 Jquery UI custom Update to v1.8.20
16
Improved webif
0842 2012.03.23 Webif Jquery Update to v1.7.2
0840 2012.03.01 Support for Tntsat viaccess 5.0
0839 2012.02.24 Jquery UI custom Update to v1.8.18
0836 2012.02.01 Webif Fix
0835 2012.01.31 NXP Reader support
0833 2012.01.29 Videoguard 2 improvement
0832 2012.01.28 NXP DVB API support
0828 2012.01.23 Improved DVBAPI support
0827 2012.01.22 Various code FIX
0826 2012.01.10 Jquery UI custom Update to v1.8.17
0825 2012.01.07 Softcam Fix, CardID Reader Fix
0824 2012.01.06 X86 Improved webif
0823 2012.01.04 Support VideoGuard BSkyB (0963)
0822 2011.12.25 Softcam fix, XCAS fix
0821 2011.12.18 Softcam, NAGRA and platform various fix
0820 2011.12.16 Support for CCcam 2.3.0
0819 2011.12.10 Support for M7 1802
0818 2011.11.24 Webif Jquery Update to v1.7.1
17
0817 2011.11.18 Viaccess parental control fix
0816 2011.11.11 Support for new IPBox model, PMT parse fix, newcamd filter fix
0815 2011.11.08 Webif Softcam Fix
0814 2011.11.05 Webif Jquery Update to v1.7
0813 2011.11.03 Webif Fix
0808 2011.10.15 Improved webif
0806 2011.10.10 VG2 EMM Global fix, webif fix
0804 2011.10.09 VG2 ECM parser fix, webif fix
0802 2011.09.29 Softcam fix
0801 2011.09.24 Improved webif
0799 2011.09.17 Improved webif
0793 2011.09.15 ECM by webif fix
0792 2011.09.15 Improved webif
0791 2011.09.13 Webif Jquery Update to v1.6.4
0789 2011.09.12 Improved webif
0782 2011.09.03 Various stability fix
0776 2011.08.31 XCAS fix, Webif improvement
0770 2011.08.27 Softcam fix, newcamd fix
0767 2011.08.22 Improved webif, various fix
18
0763 2011.08.21 Softcam fix, initial phoenix support
0762 2011.08.20 Improved webif, fix on softcam CA select
0754 2011.08.19 Many stability improvements, EMM logging by
status bytes, EMM flood check
0746 2011.08.15 Switch to version 3.1 due to major improvements
new memory management, best multi threading
0739 2011.08.15 Smargo FIX
0733 2011.08.14 VG2 EMM algo check removed
0725 2011.08.08 Jquery UI custom Update to v1.8.15
Improved webif
0712 2011.07.30 Viaccess Emm Improved
Bugfix softcam DVB
EMM Filter in reader
0704 2011.07.29 Improved webif
0702 2011.07.28 Improved VG2 EMM parser, webif
0699 2011.07.27 Improved VG2 EMM parser
Improved Webif
Bugfix protocol Newcamd
0695 2011.07.26 Improved webif with CA system specific informations
19
Videoguard 2 EMM Global management
0694 2011.07.24 Webif improvement
Bugfix SF on fast channel change
Bugfix SF on ECM callback to a dead session
0692 2011.07.24 Webif improvement
0691 2011.07.23 Webif Code Fix
0690 2011.07.16 Webif Code Fix
0686 2011.07.16 Webif improvement
SID filters
0681 2011.06.28 IRD model in reader configuration, webif improvement
0680 2011.06.24 Added TVFilter "B" to manage card hops (ex. for emu)
Improved Videoguard2 EMM filter
Saving EMM E-Mail received
Webif improvement
0676 2011.06.12 SECA bugfix
0675 2011.06.12 Webif Menu improvement
0674 2011.06.12 Webif Code Fix
0673 2011.06.11 Webif improvement
0672 2011.06.04 Webif Code Fix
20
0671 2011.06.04 Bugfix in load balancing
0668 2011.06.04 Webif Minor code Fix
0665 2011.06.04 Webif synologic check
Balancing value display
0664 2011.06.03 Ajax CheckPoll Fix
0663 2011.06.02 Webif Code Fix
0662 2011.06.02 Load balancing support, webif improvement
0661 2011.05.23 Webif Code Fix
New toolchains ARM EABI / Synology
0659 2011.05.23 Webif CSS Optimization
0658 2011.05.23 Webif Improvement
0657 2011.05.22 Webif Fix
0656 2011.05.22 Webif Improvement
Clock Upgrade v2.3.2
0655 2011.05.20 Minor Code Fix
0654 2011.05.19 Counter Tiers Viaccess Fix
Minor Code Fix
0653 2011.05.19 Webif AreaEM Fix
0652 2011.05.18 Webif checkpool Fix
21
0651 2011.05.18 Webif Fix
0650 2011.05.17 Jquery UI custom Update to v1.8.13
0649 2011.05.15 Bugfix <a id="JADVKey_1_0_2" class="JADV_Spot" href="http://click.juiceadv.com/banner_showext.asp?url=3099477&redirect=relink%2Easp%3Fkey%3D677" target="_blank">PC</a>/SC
0648 2011.05.13 Webif Fix identification of the Server
0647 2011.05.13 Webif Jquery Update to v1.6.1
0646 2011.05.07 Webif Json parse fix for CT
0645 2011.05.04 Webif Function fix
0644 2011.05.04 Webif Jquery Update to v1.6
Jquery UI custom v1.8.12 add
Jquery Booklet Update to v1.2.0
Minor Code Fix
0643 2011.04.23 Support for Clarke Tech
0642 2011.04.09 Webif fix
0641 2011.04.08 Smargo driver revert to 559 due hangs
Webif improvement
EMM from network fix
0640 2011.03.17 SCI reader ATR fix
WAN mode to discourage payserver
Added structure and ajax support for genuine unicam peer
22
Added anti-sniff function
Webif fix
0639 2011.03.14 Commit Error
0638 2011.03.14 Minor Code Fix
0637 2011.03.14 Fix for IE on Call jquery ajax whit status 12152
0636 2011.03.13 Viaccess Fix
0635 2011.03.12 Minor Code Fix
0634 2011.03.12 Code Tooltip Rewrite
Fix for Chrome on Call jquery ajax whit status 0
Css tooltip fix
0633 2011.03.06 Log fix
0632 2011.03.03 Added flags to enable/disable CA fixes
Updated SoftCam.Key
Support SkyDE + Polsat Nagra
Newcamd CWS mode
0631 2011.03.03 Webif minor code fix
0630 2011.03.03 Webif Fix and Clean tooltip code
0629 2011.02.28 Webif remove timeout limit
Webif call ajax set in sync mode
23
0628 2011.02.27 Webif code fix
0626 2011.02.27 Smargo fix (x86?)
Webif improvement
0624 2011.02.25 Webif minor code fix
0623 2011.02.25 Webif Jquery Update to v1.5.1
Call ajax/json FIX
0622 2011.02.23 Support for stealth modes on Newcamd/CWS
0621 2011.02.22 Support for Newcamd/CWS
Videoguard2 9993 FIX
Bugfix reader username/password length
Bugfix last activity users
0619 2011.02.18 Updated tiers, channels and softcam
0618 2011.02.13 Webif Remove lib Json and function createAJAX
Converted all call ajax/json for jQuery 1.5
0617 2011.02.13 Support for M7 CaId 1804
0616 2011.02.10 Webif Count Hops for EMU in Softcam/Session Fix
0615 2011.02.10 Webif Changelog Update
0614 2011.02.10 Webif Parsing INFO Fix
0613 2011.02.10 Commit Error
24
0612 2011.02.10 Webif Jquery Update to v1.5
0611 2011.02.06 Webif Fix
0610 2011.02.06 Webif improvements
Bugfix TNT Sat
Added parameter "emmcache" in [reader]
0609 2011.01.26 Webif Changelog Update
0608 2011.01.26 Json library Update to 20-01-2011
0607 2011.01.24 Webif Changelog Update
0602 2011.01.21 Webif improvements
Support for AZBox Enigma 2
Fix SF in CCam servers
0601 2011.01.16 Webif improvements
0600 2011.01.15 Webif improvements
SF fix in ATR discovery, EMM Viaccess, CCcam send card
0599 2011.01.14 ATR and HB in Webif
Webif improvements
Softcam and tiers updated
25
Increased ECM/EMM pool size
EMM provid fix
0598 2011.01.09 Webif improvements
0597 Fix EMM history
Fix SF in WEB server
0596 2011.01.06 Webif improvements
0595 EMM history for softcam, users and readers
Support web server caching
0594 2011.01.01 Webif improvements
0593 Fix SF in ATR parsing
Periodic removal of orphan EM items
0592 2010.12.26 Added readme.txt and changelog.txt to Web Interface
0591 Bugfix Web Interface
0585 2010.12.24 Stability improvements and new Web Server (version 3)
0458 2010.09.03 Using of memory pools (version 2.5)
0218 2010.01.12 Rewrite in C++ (version 2)
0178 2009.12.22 Rewrite using p_threads
0006 2009.11.02 Start of V1 main project in C
26
© 2009 - 2013 " unicam " All Rights Reserved, Unless Otherwise Stated.
Continuarea...................
###########################RuBeN#Config#SkyItalia###########################
[global]
#debuglevel = 1023
allowwan = 1
#traceconf = /var/bin/log/unicam_conf.log
#accounttvf = D:deny
##accounttvf = D:allow W:1
#readertvf = D:allow W:2
#readertvf = J:deny H:8
#readertvf = J:deny C:0919
#readertvf = J:deny C:093B
#readertvf = J:deny C:09CD
#readertvf = J:deny C:183D
#readertvf = J:deny C:1803
#readertvf = J:deny C:1804
#readertvf = J:deny C:1805
#readertvf = J:deny C:0500 P:023800
#readertvf = J:deny C:0500 P:040810
#readertvf = J:deny C:0100 P:B1
#logfile = /tmp/unicam.log
#debuglevel = 2047
accounttvf = D:allow C:09cd P:000000 W:7
readertvf = D:allow H4
[softcam]
enabled = 1
processemm = 1
maxemmhops = 2
waitlocal = 2
[memory]
fthreads = 6
#accounts = { pool size of accounts, default 100 }
#cards = 3000
#readers = { pool size of readers, default 20 }
emitems = 2000
filters = 1000
#goods = { pool size of good cards per channel, default 5000 }
#servers = { pool size of servers, default 5 }
sessions = 1000
#history = { pool size of history, default 5000 }
[webserver]
enabled = 1
port = 7777
username = RuBeN
password = BliNeR-KeY.CoM
#############################Smargo#Reader##############################
[reader]
enabled = 1
label = smargo_1
protocol = smargo
device = /dev/ttyUSB0
mhz = 1600
#cardmhz = 1200
processemm = 7
boxid = 12345678,123456
marryinfo = 0000000000000000000000000000000000000000000000000000
#emmmaildir = /media/hdd/log/emailsky/
#emlogfile = /media/hdd/log/emm09cdtest.txt
#emlog = all
#emlogsb = 9001,9021,9081,90A1,9801,9821,9881,98A1,9000,9020
#emlogsb = 9000,9020
emmlogfilter = nsb,all,all
#ecmlogfilter = nsb
flags = query
emmflood = 1000,0,0
#############################Internal#Reader##############################
[reader]
enabled = 1
label = skyitalia_Sport
protocol = sci
device = /dev/sci0
mhz = 1200
processemm = 7
emlog = all
emlogsb = 9000,9020
ecmlogfilter = nsb
flags = query
#emmflood = 1000,0,0
[reader]
enabled = 1
label = Skyitalia_Cinema
protocol = sci
device = /dev/sci1
mhz = 1200
processemm = 7
emlog = all
emlogsb = 9000,9020
ecmlogfilter = nsb
flags = query
#############################Server##############################
[server]
enabled = 1
label = server1
protocol = newcamd
port = 12000
reader = smargo_1
software = newcamd
processemm = 7
#antisniff = 1
[server]
enabled = 1
label = server2
protocol = newcamd
port = 12001
reader = skyitalia_Sport
software = newcamd
processemm = 7
#antisniff = 1
[server]
enabled = 1
label = server3
protocol = newcamd
port = 12002
reader = Skyitalia_Cinema
software = newcamd
processemm = 7
#antisniff = 1
[server]
enabled = 1
label = server4
protocol = cccam
port = 12003
software = 2.2.1,3316
processemm = 7
#antisniff = 1
[server]
enabled = 1
label = server5
protocol = cccam
port = 12004
processemm = 7
#antisniff = 1
############################UniCamUser##############################
[account]
enabled = 2
user = RuBeN
pwd = BliNeR-KeY.CoM
#sendemm = 1
#viewua = 1
limitlogin = 1
[account]
enabled = 2
user = RuBeN_2
pwd = CubaSAT
#sendemm = 1
#viewua = 1
limitlogin = 1
[account]
enabled = 2
user = RuBeN_3
#sendemm = 1
#viewua = 1
limitlogin = 1
[account]
enabled = 2
user = RuBeN_4
pwd = CubaSAT
#sendemm = 1
#viewua = 1
limitlogin = 1
[account]
enabled = 2
user = RuBeN_5
pwd = CubaSAT
#sendemm = 1
#viewua = 1
limitlogin = 1
N: localhost 12000 RuBeN BliNeR-KeY.CoM 01 02 03 04 05 06 07 08 09 10 11 12 13 14
oppure
C: localhost 12003 RuBeN BliNeR-KeY.CoM
_______________________________________
N: localhost 12000 RuBeN_5 CubaSAT 01 02 03 04 05 06 07 08 09 10 11 12 13 14
oppure
C: localhost 12003 RuBeN_5 CubaSAT
vedete voi ora le c o n le carte ca dare
_______________________________________________________
Unicam cinfig by RuBeN
CubaSAT & BliNeR-KeY.CoM
