Black Hole Vu+ Solo2 v.2.0.1 OE 2
Black Hole 2.0.1 OE 2
What is new ?
- New drivers (Solo2)
- Change feed system with full paths for all machines
- Update Videomode system plugin
- Update en translation
- Black Hole Speed: fully remove the disabled plugins from the system to increase speed and free flash space
- fix timezones
- fix bug in system info panel
- fix bug in device panel
- fix bug in image update
- fix bug in autoswap
PLEASE NOTE:
YOU MUST install this image in FLASH.
You CANNOT use online update to upgrade image from 2.0.0 to 2.0.1.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
