salut, stie cineva ceva despre acest receiver?Openbox X5 cum lucreaza cu cccam?
ca si predecesorul sau S10?
astea sunt caracteristicile pe care le-am gasit la el
daca are cineva in dotare sau a incercat asa ceva il rog sa posteze rezultatele obtinute
multumesc
Openbox x5 hd digital satellite receiver DVB
Skype:artsatwillow
Hotmail:artsat132
1. Sunplus1512A Processor;
2. Full HD PVR 1080P, with 2 USB;
3. Support 3G Modem, USB Wifi;
4. Support Internet Ethernet, Youtube, Youporn, Gmail, Weather Forecast, Google Maps....
Main Feature:
Electronic Program Guide (EPG) for on screen channel information
Subtitle supported
Teletext supported by software emulation
Parental lock facility by channel and program event
Program and Channel information transfer from receiver to receiver
HDMI HD Video/Audio Output
USB 2.0 Host
LED Display for service information
RTC (Real-Time-Clock)
Time Shift
Video Recording
Recording one channel and Time Shifting another channel (optional)
FullHD 1080p output via HDMI
AVI, MKV, MPG, TS, WMA, WMV, M2TS, FLV, DAT, ASF, MP3 playback
Software Upgrade support via USB, RS232 or Internet
Message, FAQ and User Manual support
Download files from FTP server
Award winning Dual-boot Linux Receiver
Conax Embedded Card Reader
Wireless Network & 3G Modem Support
Full HD-1080p
Features:
Ø High-performance 667MHz 32-bit MIPS 24KEc Processor
Ø Supports MPEG-2 (ISO/IEC 13818-2) MPaHL and MPaML for HD and SD decoding
Ø Supports MPEG-4 (ISO/IEC 14496-2) extended ASP
Ø Supports H.264 (MPEG-4 AVC, ISO/IEC 14496-10) MP/HPaL4.1 for SD and HD decoding
Ø Supports RealVideo(RealPlayer v8,9,10), DivX 3.11/4.12/5/6/HD, and Xvid,Dolby
Ø Supports WMA and WMA-pro, Dolby MS10 option, RealAudio
Ø Supports various bit rates for MPEG-1 Layer I/II, AC-3 and E-AC-3
Ø Supports HDMI 1.3 transmitter with HDCP, 1080i/p, 720p,576i/p and 480i/p outputs
Ø Supports dual USB2.0 EHCI host controllers with PHY embedded
Ø Supports 1-bit or 2-bit SPI flash memory
Ø IR receiver/transmitter
Ø VFD driver interface
Ø Supports dual Smart card controller interfaces
Ø Supports PCMCIA controller interface for CI/CI+ applications
Ø MHEG5 HD middleware UK DTG Certified
Ø 10/100 MAC with PHY
Ø Automatic and manual channel scan options;
Ø Automatic service scan
Ø Channel-change time < 1 second
Ø OSD in many languages and skin-support
Ø Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish,
Ø Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable
Ø LED Display
Ø Analog audio output: stereo(L+R);
Ø YCbCr available;
Ø 1 x Scart (RGB, FBAS or S-Video)
Ø Screen format: auto, 4:3, and 16:9;
Ø Upgrade software through USB2.0 port;
Ø Powerful program management function, parent lock;
Ø Directly bouquet-lists
SYSTEM RESOURCES
Main Processor: 450M Hz based CPU
Flash Memory: Nor flash: 8MB X 1 ; Nand flash:512MB X 1
DDR SDRAM: DDR2 128MB x 2
Tuner/Front-end
Tuner Type: DVB-S / DVB-S2
Input Connector: F-type, Connector, Female
Loop Through: F-type, Connector, Female
Signal Level: -65 to -25 dBm
LNB Power & Polarization: Vertical: +13V/+14V, Horizontal: +18V/+19V, Current: Max. 500mA, Overload Protection
22KHz Tone: Frequency: 22±1KHz
DiSEqC Control: Amplitude: 0.6±0.2V, Version 1.0, 1.1 1.2, USALS Available
Demodulation: QPSK, 8PSK
Input Symbol Rate: 2-45 Mbps, Convolution Code Rate
1/2, 2/3, 3/4, 5/6,7/8,1/4,1/3,2/5,3/5,4/5,8/9,9/10 and Auto
MPEG TS A/V Decoding
Transport Stream: MPEG-2, H.264
Input Rate: Max.120Mbit/s
Aspect Radio: 4:3, 16:9, Letter Box
Video Decoding: MPEG-2, MP@ML, MPEG-4 part 10/H264
Video Resolution: 720*480P/I, 720*576P/I, 1280*720p,1920*1080i, 1920*1080p
Audio Decoding: MEPG-1 layer I/II, Mpeg2 layerII, Dolby digital
Audio Mode: Left / Right / Stereo/ Mono
Sampling Rate: 32, 44.1 and 48KHz
A/V & DATA INPUT/OUTPUT
TV-SCART: Video CVBS/RGB output, Audio L/R output
RCA A/V: Video CVBS output, Audio L/R output
S/PDIF: Coaxial, Digital Audio or Dolby Digital Bit Stream Output
RS-232C: Transfer rate 115.2Kbps, 9 pin D-sub Type
RJ-45: 10M/100M
USB: One USB 2.0 slot Compatible for Host
HDMI: VER1.2, Type A
POWER SUPPLY
Input Voltage: Free Voltage (100~240V AC, 50/60Hz)
Power Consumption: 20W MAX
PHYSICAL SPECIFICATION
Size[W*H*D]: 220mm*46mm*169mm
Net Weight: 1.0KG
Operation Temperature: 0°C~+45°C
Storage Temperature: -10°C~+70°C
Storage Humidity: 5%~95% RH (Non-Condensing)
