Vand urmatoarele
1.Produs: WDTV Live fullHD media player
Descriere:
File Formats Supported
Video - AVI (Xvid, AVC, MPEG1/2/4), MPG/MPEG, VOB, MKV (h.264, x.264, AVC, MPEG1/2/4, VC-1), TS/TP/M2T (MPEG1/2/4, AVC, VC-1), MP4/MOV (MPEG4, h.264), M2TS, WMV9
Photo - JPEG, GIF, TIF/TIFF, BMP, PNG
Audio - MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby Digital, DTS
Playlist - PLS, M3U, WPL
Subtitle - SRT, ASS, SSA, SUB, SMI
Note:
- MPEG2 MP@HL up to 1920x1080p24, 1920x1080i30 or 1280x720p60 resolution.
- MPEG4.2 ASP@L5 up to 1280x720p30 resolution and no support for global motion compensation.
- WMV9/VC-1 MP@HL up to 1280x720p60 or 1920x1080p24 resolution. VC-1 AP@L3 up to 1920x1080i30, 1920x1080p24 or 1280x720p60 resolution.
- H.264 BP@L3 up to 720x480p30 or 720x576p25 resolution.
- H.264 MP@L4.1 and HP@4.1 up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution.
- An audio receiver is required for multi-channel surround sound digital output.
- Compressed RGB JPEG formats only and progressive JPEG up to 2048x2048.
- Single layer TIFF files only.
- Uncompressed BMP only.
Physical Specifications
Interface Ethernet, HDMI, Composite A/V, Component video, USB 2.0
Physical Dimensions
English
Height 1.57 Inches
Length 3.94 Inches
Width 4.94 Inches
Weight 0.67 Pounds
Metric
Height 40 mm
Length 100 mm
Width 125.5 mm
Weight 303 g
Environmental Specifications
Temperature (English)
Operating 41° F to 95° F
Non-operating -40° F to 149° F
Temperature (Metric)
Operating 5° C to 35° C
Non-operating -40° C to 65° C
Electrical Specifications
Current Requirements
Power Dissipation
AC Input Voltage 100-240 VAC
Accesorii:
telecomanda,adaptor AC
Pret:
250 lei
Garantie: nu
Alte detalii: firmware modificat
Schimb cu: nu
Contact:in PM
2.Produs: Receptor satelit HD Scorpion 801HD PVR
Descriere:
Scorpion 801 HD Pvr,cu conf. 3G, are Youtube player,Media Player foarte bun,ruleaza cccam,are 24 servere publice cu principalii provideri.
Receptor satelit HD multimedia cu sistem de operare Linux si cititor de card Conax incorporat.
Descriere produs:
- Linux operating system - Cccam, G-Share, GSh2, NewCS
- Conax CA Reader hidden behind front panel;
- Ethernet port connected to the wide world;
- Full Media Player to support AVI, MKV, MP4, VOB, MPG, . FLV, WMV etc.
- Youtube;
- Radio online;
- USB 2.0 PVR - Record and play HDTV content;
- USB manager;
- Real Time Shift - do not miss any exciting moments;
- Software update through USB interface.
- Support USB stick and Hard Drive Disk;
- DVB-S / DVB-S2 Satellite Compliant (MPEG 2/MPEG 4/H. 264)
- DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) Compatible
- SCPC & MCPC Receivable from C/Ku Band Satellites LNB Supported;
- Variable Aspect Ratio (4: 3, 16: 9) with Pan Vector or Letter Box;
- Output Resolution: 576p & 576I, 720p & 1080I;
- 8 Favorite Groups;
- Parental Lock (Channel Lock);
- Four Kinds of Sort Function for Channels;
- Onscreen Display with True full Color (32 bits) Resolution;
- 4 digits channel display;
- Receiver operational by remote and front panel;
- Teletext and Subtitle Supported (OSD & VBI);
- Blind Scan, TP Scan, Satellite Scan, Multi Scan, network search;
- 7 days EPG (Electronic Program Guide) for Onscreen Channel Information, pip
- Now and Next EPG with extensions info;
- Supported FTP Download S/W, Channel List, Message and other additional information.
- OTA Supported;
- Supported Unicable;
- Multi Pictures and PIP supported;
- PIG (picture in graphic) Small screen picture and zoom in function;
- Supported Setting timer, you can add up 8 timer event at most.
- S/W download, upload and download channel data;
- Backup channel list and restore channel list;
- Supported JPEG, BMP format;
- Wireless dongle support incl WEP encryption;
- Multi Menu Languages: English, German, Dutch, French, Swedish, Spanish, Italian, Polish, Arabic, Persian, Turkish, Russian, Ukraine, Greek, Thai
- Direct FTP access;
- Windows Share system;
- Bittorrent;
- 10.000 channels memory.
Accesorii:
telecomanda
Pret:
500 lei
Garantie: nu
Schimb cu: nu
Contact:in PM
3.Produs: Desktop 16-port 10/100 Mbps Fast Ethernet Switch
Planet FSD-1603
Descriere: [Only registered and activated users can see links. Click Here To Register...]
Key Features
Comply with IEEE802.3, 10Base-T, IEEE802.3u, 100Base-TX
16-port 10/100Mbps Auto-Negotiation ports-- 10/20Mbps, 100/200Mbps Auto-sensing
Compact size design for wall mount or desktop placement
High performance Store-and-Forward Switching Architecture
Runt and CRC filtering
Flow control (Back Pressure) supports in half-duplex mode
8K MAC Address Table, automatically learning and aging
4-Mbit packet buffer
LED indicators array for easy diagnostic, troubleshooting
Plug-and-Play Installation
Auto-MDI/MDIX on each port
SPECIFICATION
Product
16-port 10/100Mbps Fast Ethernet Switch
Model
FSD-1603
Standard
IEEE 802.3 10Base-T Ethernet
IEEE 802.3u 100 Base-TX Fast Ethernet
IEEE 802.3x PAUSE Frame flow control
Ports
16-STP
LED Display
One for Power, Link / Act and 100 per port
Mac address
8K
Switch Fabric
3.2Gbps
Data buffer
4-Mbit
Network Media
100Base-TX: RJ-45 STP/UTP, Category 5 cable, up to 100m
10Base-T: RJ-45 STP/UTP, Category 3 ~ 5 cable, up to 100m
Dimensions (mm)
267mm x 79mm x 26mm (WxDxH)
Power Requirement
DC12V, 1A
Temperature
Operating: 0 ~ 50 degree C,Storage: -10 ~ 70 degree C
Humidity
Operating: 10% ~ 90%, Storage: 5% ~ 90%
Emission
FCC Class B CE
Accesorii:
adaptor AC
Pret:
200 lei
Garantie: nu
Schimb cu: nu
Contact:in PM
Se adauga
4.Produs: Sagem Dbox2-satelit
Descriere:
Sagem Dbox2 satelit (Intel 1xChip) softat cu ultima imagine Enigma1 Powerboard-Enigma si emu cccam 2.3.0 pentru CS.
Accesorii:
telecomanda
Pret:
100 lei
Garantie: nu
Schimb cu: nu
Contact:in PM
Sagem Dbox 2 s-a dat.
Raman:
1. Receptor satelit HD Scorpion 801HD PVR - 470 lei
2. WDTV Live Full HD - 230 lei
3. Switch 16 porturi -140 lei
Receptor satelit HD Scorpion 801HD PVR s-a dat
Raman:
