Black Hole 1.7.7 Light (No HbbTv)
Due to many requests from users that don't need HbbTv the Black Hole team have
built a special light version of 1.7.7
This image without HbbTv reduces the size of the flash allowing for an improved performance.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
