Black Hole Vu+ Ultimo 1.7.1 Server Tuner
1) New New New Tuner Server feature working on lan, wan and DLNA
2) Dvb-App updated to: 20120120
3) Vu+ drivers updated to: 20120118
4) New Plugin Vuplus Event (substitute VU+ genuine)
5) Meoboot 1.0
3) Mute button fixed
4) Army MooD skin updated
5) Black Hole Mount Wizard removed
6) Network browser and mount manager included in Bh extra settings
7) Nfs Server now fully auto-configured and is up and running by default
8) Wifi drivers changes:
- removed rt2800 driver and replaced with RT3070
9) Usb Tuners drivers changes:
- USBTuner 0.3.8: more stable, some bugfixes, no hard disk usage
- replaced A867 driver with AF9035
About new feature Tuner Server:
This feature will allow you to share the tuners of this box with another Vu+ box, a PC, a Ps3 and/or a compatible UPnP device in your home network.
The server will build a virtual channels list in the folder /media/hdd/tuner on this box.
You can access the tuner(s) of this box from clients on your internal lan using nfs, cifs, UPnP or any other network mountpoint.
The tuner of the server (this box) has to be avaliable. This means that if you have ony one tuner in your box you can only stream the channel you are viewing (or any channel you choose if your box is in standby).
Remember to select the correct Audio track in the audio menu if there is no audio or the wrong language is streaming.
NOTE: The sever is built, based on your current ip and the current channel list of this box. If you change your ip or your channel list is updated, you will need to rebuild the server database.
After the server has been built you can access it from the Media Player of the client.
1) To connect via lan you have to mount the /media/hdd folder of this box in the client /media/hdd folder. Then you can access the tuners server channel list from the client Media player -> Harddisk -> tuner.
2) To connect via UPnP you have to start Mediatomb on this box and then start Djmount on the client. Then you can access the tuners server channel list for the client Media Player -> DLNA -> MediaTomb -> playlists.
You can access via the client Media Player, the channel list on the server:
Warning: because UPnP Mediatomb uses alot of system resources it is STRONGLY suggested you connect to the Tuner server via Lan and not via UPnP.
NOTE about UPnP: Because UPnP requires alot of memory, you should only use it if you need to access your box from a PS3 or other device that cannot be mounted via Lan. Also, After the server has been built we strongly suggest you delete the Bouquets directory that are not really needed BEFORE you start Mediatomb. This will save alot of memory and resources..
If you want to use UPnP remember that Mediatomb will take some time to import all the channels in the database. Connect to the Mediatomb webif to follow the importing progress when you start Mediatomb for the first time.
To share your Vu+ box hdd in the easiest way possible, the Black Hole mount wizard has been removed and substituted with the default network wizard and mount manager.
The Server Tuner Feature have been tested and reported working with
VU+ server -> Vu+ client on Lan
VU+ server -> Vu+ client on DLNA
VU+ server -> Ps3 client on DLNA
Vu+ server -> Pc client lan
Vu+ server -> Pc client DLNA
NOT working with TV DLNA systems
Many Thanks to Piefav for Ps3 testing
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
Download USB :
