3 Attachment(s)
OSCam_ymod v18 (softcam)
OSCam_ymod v18
OSCam_ymod is a special version of OSCam developed by yuriks.
OSCam_ymod is the emu version of OSCam
i.e. it can read softcam.key ( It should be renamed as oscam.keys)
It can handle Clines without problems.
Code:
Running Cline on OSCam_ymod
open oscam.server ( /etc/tuxbox/config/) using any linux editor
copy the following :
[reader]
label = server
enable = 1
protocol = cccam
device = dyndns of cs_server,port
account = user,password
group = 2
CAID =
Ident =
Services =
Start OSCam_ymod
Now ur cline works on OSCam_ymod
New version 18t-23 of oscam mod from yuriks
- using external keys (from file softcam.keys) for provider TNTSat
- Added emu Nagra2
- Config reader in a single row Edit:no links to other forums
The configuration of readers in a single row
In test mode
To make configuration setting oscam.server made in a single row
[protocol server, port user, password group]
for example
[newcamd server.com,1111 user,password 1]
this are the main parameters - the rest you can specify the names of the parameters
for example
[newcamd server.com,1111 user,password 1 label=reader1 ident=0500:040600]
In one parameter notallowed no spaces, ie
label = reader1 - not
New version 18t-24 of oscam ymod from yuriks
In latest version you can add newcamd reader in format:
PHP Code:
[newcamd s.server.com 10001 testuser testpassword][newcamd s.server.com 10002 testuser testpassword][newcamd s.server.com 10003 testuser testpassword]
New version 18t-25of oscam ymod. All thanks to yuriks!!!
- Fixed a bug in setting up a single line
- Corrected the work emulyator Via3 on channel NT1 (TNT)
- adaptation oscam-linux-pc to work with vdr-dvbapi-plugin
3 Attachment(s)
Si pentru SH40, plus un exemplu de cfg
Functioneaza pe SH40, e stabil.
O sa apara si la RSP panel curand.
server cccam ?
M-am jucat si eu cu el de vreo 3 saptamini pe un IPbox 9000 (combo cablu N2 si sat). La N2 merge f.bine, in schimb n-am reusit sa-l fac sa mearga in séca1 (RAI).
La-ti testat si ca server cccam ? Daca merge bine, poate ma ajutati si pe mine cu setari si teste, am 2 carduri Via de impartit dar la ora asta nu am server functional.
Multumesc pentru ajutor.
@zildan - Din pacate la RSP Panel nu a aparut nici pana astazi. Eu l-am testat pe o alta imagine si e foarte bun. Astept sa-l pot gasi si la panel.
:clap:
Forumul oficial al lui Yuriks sa mutat in reţeaua TOR la următoarea adresă: [Only registered and activated users can see links. Click Here To Register...]
Pentru a-l accesa este nevoie de Tor Browser Bundle de aici: [Only registered and activated users can see links. Click Here To Register...]
3 Attachment(s)
OSCam-Ymod yuriks version 18 49
- Added option pidfile
- Filter class is able to exclude certain channels ( error in parsing if more than one sidov )
class = e6 (4e86) - only the class e6 without channel 4e86
class =! e6 (4e86) - all classes except e6 or channel 4e86
- Fixed parsing of the data provider in the encoding Dre
- Added option to filter dvbapi privatedata
P or I: CAID: [provider ID]: [service ID]: [ECM PID]: [CHID]: [PRIVATEDATA]
- Fixed an emulator provider tnt
