Today will be releasead new Black Hole 1.7.0 Full Multiboot for all Vu+ boxes
vuplus-community.net
Black Hole Vu+ Duo 1.7.0 Multiboot Full Backup
There are 2 big news items in this Black Hole release.
- Meoboot Version 1.0
- Full Backup utility
1) Meoboot version 1.0 is a NEW VERSION entirely recoded for kernel 3.1.1 images.
This version of Meoboot is 50% faster than the old version and only compatible with images that share the new kernel 3.1.1.
As you know the new kernel 3.1.1 based images have a new filesystem (Ubifs).
Meoboot can extract a Ubifs filesystem and install a full image in about 4 minutes on Vu+ boxes and is much faster than old versions at startup.
WARNING: THERE IS AN IMPORTANT CHANGE IN MEOBOOT 1.0: This version of Meoboot accepts images in USB.zip format and NOT in NFI format. This is because images in USB format are easier to find and much more readily available.
WARNING2: This version of Meoboot accepts only 3.1.1 kernel based images.
2) New Full Backup Utility.
This new Black Hole utility will complete the Black Hole tools. You can find it in the main menu. The Black Hole Full Backup will allow you to backup all your images in the original USB.zip format. This means that after you make a backup you can restore it in it's entirety, you flash your set top box with your own backup.
This new feature is based on the original script of Pedro_Newbie.
What is New ?
New Skin Army MooD HD
Default Lcd skin with picons support by Matrix10
Drivers: 04.jan.2012
Dvbapp updated to o7.jan.2012
Genuine Vuplus plugin
Vuplus plugins updated
Meoboot 1.0
Bh Full Backup
Numai ca, nesatuii astia cu vu+ au dat jos serverul:grin:
An unexpected database error occurred. Please try again later.
S-au speriat de clone si cei de la Vu+ :DQuote:
Originally Posted by lao [Only registered and activated users can see links. Click Here To Register...]
Parca exista separat de mai mult timp pluginul asta. La astia n-am auzit de bomba, e doar ca sa fii sigur ca e vu.
Site-ul e tot cazut....
---------- Post added at 21:24 ---------- Previous post was at 19:29 ----------
Dupa ce a incercat sa se scoale de cateva ori, si a crapat instantaneu, acum merge taras ... Cum am zis, astia cu vu sunt criminali nu te lasa in pace deloc...
PS Numai ca va trebuie cont la ei
---------- Post added at 22:09 ---------- Previous post was at 21:24 ----------
Si pentru [Only registered and activated users can see links. Click Here To Register...]
Black Hole 1.7.1 Tuner Server will be released today !!
This feature will allow you to share the tuner(s) of this box with another Vu+ box or a PC in your home network.
The server will build a virtual channels list in the folder /media/hdd/tuner on this box.
You can access the tuner(s) of this box from clients on your internal lan using nfs, cifs, UPnP or any other network mountpoint.
