Egreat R200s 3D, New 3D HD media player
Am deschis acest thread ca un preview la noul model care sper sa fii aparut pe afara si poate luna viitoare si la noi , sau cel putin de sarbatori ca un cadou de Sfantul Nicolae
Cele de mai jos sint de pe un site de afara si acest model se vinde la un pret informativ de 216$ , dar iata o descriere la ce stie/este dotat acest nou model :
Citez " - R200S Features :
Pure aluminum case with wire-drawing workmanship, enjoy high quality life.
Top hardware design, PCB proper layout and exquisite work, enable player work stable and efficient;
adopt lead-free process, compliance with RoHS standard.
Support 3D movie decode and playback
Support 2D movie convert to 3D image
Support USB 3.0 SLAVE
Support USB 3.0 HOST
Support 16DB double antenna wireless WIFI
Support USB keyboard and USB mouse
Can play original BD disk,Support BDMV full navigation
BD full navigation: support multi track and multi subtitle switch , chapter selection function etc.
Support 7.1 pass through,Support Dolby True HD,DTS-HD MA,LPCM,Dolby Digital Plus
By forcing upgrades can be upgrade between two different firmwares.
Support USB ,SD/MMC
Support 10/100M
Built-in 3.5" mobile rack
Connect 3TB HDD, BD ROM and DVD ROM by SATA cable externally.
LED panel display.
Powerful online video capabilities, support Tianyi, BesTV, Youku HD, SOHU HD, QQLIVE, ku6, Sina,joy and so on.(Chinese region)
Support SAMBA share, support BT download
Support gapless playback: TS, M2TS.
Bookmark function: record the last playback time automatically.
Support previewing subtitle.
Adjust external subtitle at random: size, color, time-lapse, upper or down position.
Support playback according to time seeking: time jump and time scroll two methods.
Support slide show, music background, screen savor, movie preview, movie rating.
Video Files Playback Support BD-ISO,mostly use BD-remux,BD-RE,
BDRip and some other ways to produce high-definition audio and video files (extension. TS,. MKV,. AVI, etc.).
Support APE,FALC,OGG,AAC,M4A,WAV,WMA,MP1,MP2,MP3,MPA
Compatible with HTML 5.0 web browser
Support Adobe Flash 6.7.8 playback
HDMI 1.4 Perfect HD display, smoothly playback, freely remote control.
Product size:197*180*50MM
Main Hardware parameters:
CPU:RTD1186DD 750MHz
DDR2 SDRAM: 512MB DDR3 SDRAM
NAND FLASH:4GB Nand flash
Main output port: Video/Audio output ports:
- HDMI 1080P HD output port(V1.4), resolution options: 480P,576P,720P@50Hz, 720P@60Hz,1080I@50Hz, 1080I@60Hz,1080P@50Hz, 1080P@60Hz
- Y/Pb/Pr, resolution options:480P,576P,720P@50Hz, 720P@60Hz,1080I@50Hz,1080I@60Hz,1080P@50Hz,1080P@60Hz
- AV output port(Composite) , 576I@PAL,480I@NTSC
- Audio output Ports: Stereo , Optical and coaxial
Other ports:
USB 2.0 HOST ports x 4
USB 3.0 HOST ports x1
External SATA port, connect with HDD or BD ROM or DVD ROM directly without extra power.
Internal 3.5" mobile rack.
USB 3.0 SLAVE x 1, can transfer data to PC directly, speed up to 5.0Gb/S(Note: Compatible 2.0 PC)
Network ports: 10/100M RJ45 port, support x 1, playback by LAN;
Support USB 802.11n WiFi dongle(recommend RTL8191SU solution); Built-in MINI-PCI card(Pro version)
SD/MMC Through this interface can be individually play SD / MMC multimedia files.
File formats - Video Container:
RM/RMVB
MPEG1/2/4 Elementary (M1V, M2V, M4V)
MPEG1/2 PS (M2P, MPG)
MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
VOB
AVI, ASF, WMV
Matroska (MKV)
MOV (H.264), MP4, RMP4
IFO
DVD-ISO,BD-ISO
MINI BD,BD-9,BD25,RBD,D5,D9,DVD,CD
FLV
swf/(.swf) *
3GP/.3gp
AVS/(.avs)
3D Bluray(DISC/ISO) or Single-File(*.ts/*.m2ts)
Video decode:
MPEG1,VCD1.0/2.0,SVCD( up to1920*1080@30P/60I or 1280*720@60P)
HD MPEG2 MP/HL,ISO,IFO,VOB,TS(up to1920*1080@30P/60I or 1280*720@60P)
HD MPEG4 SP/ASP,Xvid(up to1920*1080@30P/60I or 1280*720@60P)
H.264 BP@L3,MP@L4.1,HP@L4.1 (up to 1920*1080@30P/60I or 1280*720@60P)
WMV9,VC-1 AP@L3( up to 1920*1080@30P/60I or 1280*720@60P)
DivX3/4/5( up to1920*1080@30P/60I or 1280*720@60P)
XVID SD/HD( up to 1920*1080@30P/60I or 1280*720@60P)
RM/RMVB 8/9/10( up to 1280*720@30P)
AVS: Jizhum profile @ level 2.0/ 4.0/ 4.2/ 6.0/ 6.2
Audio Container:
AAC, M4A
MPEG audio (MP1, MP2, MP3, MPA)
WAV
OGG
APE
FLAC
MKA
WMA (WMA PRO)
Audio decoder:
MPEGⅠLayer 1/2/3(2-CH) and MPEGⅡ1/2(Multi-Channel)
LPCM,ADPCM,FLAC,AAC,WAV,OGG
DTS digital+stereo
Dolby Digital
RA1/RA-cook/RA-Lossless
Picture format: JPEG, BMP, PNG, GIF, TIFF, jps(3D), mpo(3D)
Subtitle format: MicroDVD [.sub], SubRip [.srt], Sub Station Alpha [.ssa], Sami [.smi], idx+sub, PGS embedded subtitle
Menu language: Standard version: simplified Chinese, traditional Chinese, English, Russian, Spanish, Czech, Dutch, Italian, French, German, Turkish, Hebrew
Subtitle language: Standard version: simplified Chinese, traditional Chinese, Turkish, Greek, Hebrew, Czech, SE European, Central European, Cyrillic, Western, UTF8
HDD format: Support FAT32, NTFS, EXT3, HFS
Accessories:
12V/3A power 1pcs
SATA cable 1pcs
Remote 1pcs
HDMI cable 1pcs
AC cable 1pcs
User manual 1pcs
Mai multe info/imaginii de la sursa : [Only registered and activated users can see links. Click Here To Register...]
