DCC-E2 v1.41/dflash_0.101
DCC-E2 v1.41
Image Backup adjusted current dFlash 0101
Gutemine has specially created a new version, because before all the commands were language-dependent and the backup feature of the DCC-E2 therefore only in German-speaking world worked. Now it should run independently of the language set on the box.
Be dFlash 0101 must be installed on a Box: IMPORTANT!
Fixed bug in the Active FTP
Due to an error, it was not possible to build up in the 'Active' mode FTP connection through a router from outside the box.
dflash_0.101
On the first page is now also the version of dFlash Dalmatians (0101) where the command line when Webif ALWAYS in English, no matter what language is set in enigma2.
This means that the people who have backup shell scripts made with wget command just once to be replaced by backup, but the DCC BernyR can modify the integration dFlash on the English syntax of the command web interface to make it so it goes in any language.
And after there were no complaints because the statically linked writenfi I have just left inside.
LG
gutemine
