BlackHole Vu+ Duo 1.6.3 Hdmi Cec
Update OE tree
Support blind scan(uno)
Add fancontrol Plugin(uno)
Add wireless usb drivers
Support more media playback(uno)
New Black Hole Hdmi Cec
(Warning: Hdmi Cec is only experimental function. It may works or not depending from your tv compatibility. Tests with latest Samsung series tv report 1-3 options working.)
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Download NFI :
Download USB :
