Buna.
Am un router topex cu openwrt.Conform tutorialul lui Rsofty am facut sa booteaza de pe stick si am instalat cccam.
Cineva are un tutorial pentru instalare samba si mondtare hdd extern (NTFS)
Multumesc
Buna.
Multumesc
Instalare SAMBA
root@OpenWrt:/# opkg update
root@OpenWrt:/# opkg install luci-app-samba
Installing luci-app-samba (0.8.8-1) to root...
Downloading [Only registered and activated users can see links. Click Here To Register...]
Connecting to 10.1.1.1:8080 (10.1.1.1:8080)
luci-app-samba_0.8.8 100% |*************************************************************************************************** ******| 2866 --:--:-- ETA
Installing samba3 (3.0.24-2) to root...
Connecting to 10.1.1.1:8080 (10.8.39.5:8080)
samba3_3.0.24-2_mips 100% |*************************************************************************************************** ******| 456k 00:00:00 ETA
Installing libpthread (0.9.29-14.3) to root...
libpthread_0.9.29-14 100% |*************************************************************************************************** ******| 19340 --:--:-- ETA
Configuring libpthread
Configuring luci-app-samba
Configuring samba3
preluat de pe alt forum, autorul tutorialului este tivcol
In legatura cu hdd exter partitionat NTSF, eu ti-as recomanda sal partitionezi EXT3, findca openwrt kamikaze (kernel 2.4) NTSF poate doar sal citesca nu si sa scrie (este READ ONLY, RO).
Dupa cum ai scris presupun ca ai instalat openwrt kamikaze kernel 2.4
Mersi Sorin.
Atunci de aia nu vede pe hard.Si o problema ca samba nu a aparut in webinterface.
Sorin,
Daca fac fat si nu ext3.O sa fie tot read only?
Primesc eroarea urmatoare cand dau comanda dmesg din putty.Totul am facut conform tutorial.
NU stiti de ce?
usb.c: USB disconnect on device 01:02.0-1.3 address 6
hub.c: new USB device 01:02.0-1.3, assigned address 7
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 7
usb.c: USB disconnect on device 01:02.0-1.3 address 7
hub.c: new USB device 01:02.0-1.3, assigned address 8
USB Mass Storage device found at 8
FAT: bogus logical sector size 0
UDP: bad checksum. From 78.174.30.222:8403 to 192.168.0.3:41534 ulen 106
usb.c: USB disconnect on device 01:02.0-1.3 address 8
hub.c: new USB device 01:02.0-1.3, assigned address 9
USB Mass Storage device found at 9
Nu stie nimeni raspunsul?
root@OpenWrt:/# /etc/init.d/usbhdd start
Mounting USB drive: mount: mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /share failed: Invalid argument
Stie cineva cum se rezolva problema?
Ce fel de hard disk ai?
Intreb fiindca eu am doua HDD-uri externe: unul de 2.5" si altul de 3.5". Primul n-are sursa, deci se alimenteaza prin portul USB, al doilea are sursa externa. Am constatat ca sursa micuta a routerului Bytton Topex nu poate alimenta un HDD extern prin USB.
Poate asta-i problema si la tine. Incearca un hard cu sursa proprie, si vezi daca reusesti.
Are sursa proprie.
Aici e tot secretul; " on /share failed: Invalid argument "Quote:
Originally Posted by battila [Only registered and activated users can see links. Click Here To Register...]
Bine Zappa.Zi-mi si mie care este secretul acolo.:P
Attached scsi disk sdb at scsi1, channel 0, id 0, lun 0
out of order segment: rcv_next 20A3A6BA seq 20A3A700 - 20A3A708
SCSI device sdb: 312581808 512-byte hdwr sectors (160042 MB)
/dev/scsi/host1/bus0/target0/lun0: p1 < p5 >
Asta am observat cand am dat comanda dmesg. Ce inseamna p5 la sfarsit?
Dupa ce ai deconectat modemul GPRS ai rezolvat cumva si cu alimentarea HDD-ului?Quote:
Originally Posted by birrbert [Only registered and activated users can see links. Click Here To Register...]
Tvicol mai propunea o solutie:
Originally Posted by tvicol
Eu vas recomanda hdd extern cu sursa proprie. Eu am unul de 1.5TB si merge perfect.
Am incercat si eu cu un hdd extern de 1TB(cu alimentare proprie) si functioneaza perfect.
Totusi daca tot nu folosesc modemum GPRS as vrea sa ii folosesc alimentarea si sa las un hdd mai mic tot timpul(pentru ftp).
