A aparut si modarea pkt dupa tideglo 1.3.0 care a aparut ieri.
Tideglo am testat eu si are un zapping mai bun decat 1.1.1 .Ar trebui sa fie si pkt la fel .
Folosesc si eu aceasta imagine versiunea usb pentru cuberevo 250 hd, e super. Au inceput sa-mi apara cateva fisiere log urmate de hostul de unde s-a facut login ex. log.192.168.1.101 in /var. Ceva rar este urmatorul fisier log.smbd
Din cate inteleg eu, a incercat cineva sa-mi intre in aparat ?Quote:
[2011/04/27 12:55:20, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 630 is running.
[2007/12/31 23:00:37, 1] lib/account_pol.c:account_policy_get(286)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
[2007/12/31 23:00:38, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 631 is running.
[2011/04/27 16:24:55, 1] lib/account_pol.c:account_policy_get(286)
[2011/04/27 16:24:56, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 629 is running.
[2011/04/27 16:29:13, 1] lib/account_pol.c:account_policy_get(286)
[2011/04/27 16:29:14, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 628 is running.
[2007/12/31 23:00:42, 1] lib/account_pol.c:account_policy_get(286)
[2007/12/31 23:00:43, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
[2011/04/27 21:09:28, 1] lib/account_pol.c:account_policy_get(286)
[2011/04/27 21:09:29, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 627 is running.
[2011/04/27 21:13:55, 0] /home/Tideglo/sh4-dev-DVB/trunk/cvs/cdk/samba-3.0.28/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 1040 is running.
[2011/04/28 10:25:00, 1] lib/account_pol.c:account_policy_get(286)
