A aparut sif extreme 1.4v1.2.0 .O recomand
Based on the latest version of the FW by E2 Tideglo Changelogs has the following:
Extreme Edition 1.4
Moved to Tideglo 1.2.0
fixed hotplug start
fixed mount hdd at startup
fixed swap mount at startup
enabled direct view of multimedia file via usb stick
enabled picons load from HDD (/media/hdd/picon)
updated Crossepg svn 241
Tideglo release 1.2.0
- fixed green button for aspect ratio options
- fixed extended audio selection
- fixed hdd mounting point on /media/hdd
- fixed no audio over HDMI on few receivers model with PCM audio-type
- fixed few incompatibility issues for some cuberevo-100hd, cuberevo-250hd and cuberevo-mini2
- fixed rewind and fast forward using numbers on .ts files (1,3,4,6,7,9)
- fixed timeshift (now seems working ok, let me know if you find more problems)
- fixed dvd player
Many thanks to:
Ipbox2008 (coder)
Skaman (coder)
Biondo79 (betatester)
Morpheus883 (Settings Creator & Betatester)
Theseven007 (Betatester)
Tideglo (Enigma2 Cuberevo Driver Boss)
Killer bestia (web master and mantainer)
Margy82(Skinner)
Genge (Betaster)
Buna tuturor!!
Am descoperit un plugin care mi-ar fii de folos da nu stiu nimic despre el. Este vorba despre torrent client.
Am avut in gemini (DM), si acolo am putut intra prin webinerface. Acuma in ip box am vazut un plugin, am
instalat, da nu dau de el , cum trebuie folosit! Nu stiti nici unu , ce si cum?
La sifteam forum nu ma descurc cu limba .:)
Multumesc de inainte pt raspuns.
Am si venit, daca cineva are timp nu se uta aici cum se face? cum se procedeza cu acest plugin?
Eu nu am reusit sa inteleg!:agresiv:
Multumesc.
Trebuie sa ai HDD
Copiezi fisierele din arhiva in directoarele imaginii
Dai atribute de executie 755 fisierelor din /bin si scripturilor
Dupa restart si pornire plugin te conectezi de pe PC la IP_boxului:9091 de unde setezi ce torrent vrei sa fie descarcat
Se spune ca nu ar merge bine daca te folsesti de box simultan pentru a te uita la tv ? :p
Multumesc. Am reusit! , Functioneza.
M-am uitat mai bine ,si am gasit si intre addons, numa nu stiam ce si cum. Am citit si aici,si mam uitat
cind am dat drumul la scriptul de pornire a scris automat cum pot sa ajung, unde vreau. Deci inca odata
multumesc,! Este folos pt mine acest plugin, nu trebuie sa tin pc la curent pt scopu asta! Si ma bucur ca
au si Ip boxuri asa ceva.
