O noua imagine iCVS DMM HD !
Acum o luna ... aparitia unei noi imagini iCVS ar fi insemnat un eveniment asteptat
... ma tem ca dupa 15 ianuarie 2011 ... evenimentul acesta nu va starni decat un
interes moderat ... pentru initiati ... pentru cei ce vor sa-si faca mana !
Da ! conform directivelor de la Zeus Broadcom ... no cams , no configs on the feed !
P.S. Suportul de decodare este activ ! si merge bine merci !
Iata release.note !
iCVS image from 04.02.2011
Version details:
Enigma2 from 04.02.2011
Plugins from 04.02.2011
Skins from 04.02.2011
Drivers from 15.12.2010 (DM500hd, DM800, DM800se, DM8000)
Drivers from 08.12.2010(DM7025)
Experimental / own update feed
Extras / included changes:
- Gemini plugin reade (GeminiWizard already included)
- switch ON/OFF EPG-Progress in %, adjoustable in the customization menu
- PipZap by @ ritzMo
- Set space between channelname and EPG info, adjoustable in the customization menu
- Picture-rotation if exif tag available, adjoustable in the customization menu
- pipZap and VirtualZap plugin.py adapted. (no crash anymore)
- dcccamd removed from the image
- own iCVS bootlogos by yvessun
- Support for Smargo usb Cardreader FTDI_SIO and PL203
- CrossEPG Release rev. 242
- Spinner fix (bootlogo)
- Startvolume set down to 30%
- Expert mode as standard in the customization menu
- Adapted view in screen HelpMenuList
- GraphMultiEPG incl. Picons
- GraphMultiEPG colored
- Adapted view in screen PluginList
- iCVS adapted Keymapxml
- Adapted view in screen Pictureplayer
- Adapted view in screen Serviceinfo
- Adapted view in screen Movielist
- Adapted view in screen ClockToText
- Change of Yes/No in the startwizard at the child safety pin question
- MHW EPG activated
New:
- sambaserver removed from the image
- Ready for Karatelight from @mamba0815 and LowFat from @gutemine
- DVD Burn removed from 8K image, can/should be installed over the feed.
- rt2570 and rt3070 WLAN drivers added to the feed
- IPv6 and CPU FREQ Kerneladaptions
- listbox_fix by @adenin
- on/off bouquet + button (direct access to the bouquet with +, selectable in menu -> customize
Further Informations:
There are no Cams, Cam Configs, Settings,... availabe on the feed.
This image can be used as a base for the Gemini plugin.
Although can be installed userscript, if you don't want to use the Gemini plugin
