Amplificator Peavey Rage® 258
Produs: Peavey Rage® 258
Descriere: are doi ani vechime dar este in conditii excelente.
Accesorii: cablu alimentare
Pret: 250 ron
Garantie: nu
Alte detalii:
The basic building blocks of the TransTube® sound are the exclusive designs of the preamp and power amp. The preamp section tailors gain to meet the need for any amount of drive, from crystal clear to thick, smooth sustain. The power amp reacts just like a tube output section by responding to the preamp with natural compression that increases as the amp gets louder. With TransTube®, you get a killer amp with widely ranging dynamics and natural "grit," just like a tube amp!
Features
- 25 Watts RMS
- 8'' (203mm) Blue Marvel® speaker
- Two channels, clean and lead
- Master 3-band EQ
- 3-position voicing switch
- Tape/CD input for practice
- Headphone jack
- Dimensions (HxWxD): 16'' (406mm) x 13'' (330mm) x 8'' (203mm)
- Weight: 11 lbs (5kg)
Schimb cu:
Contact: Pe PM sau pe E-mail-ul de la profil.
Uploaded with [Only registered and activated users can see links. Click Here To Register...]
