JaZUp by Hectore and Pr2_V.1.3
JaZUp by Hectore and Pr2 V.1.3
Please ALWAYS run JaZUp when your Azbox is still in official firmware to disable Hardware Acceleration before starting any upgrade process! Even without any USB key connected simply press Update button this will check for and disable Hardware Acceleration if needed and also uninstall Priority Manager plugins if installed.
When you install on USB please remember that JaZUp requires 2 USB keys; one with patch.bin and the other one will be used to install E2 on it (min. 256 MB required).
You Firewall can ask you to grant access from JaZUp to your Azbox please allow it.
We only use telnet and FTP.
See other included files for full details.
change log:
Code:
1.3
- Disable Hardware Acceleration even in Rescue Mode
- Uninstall Priority Manager from official firmware to avoid conflict when upgrading
- better detection of destination device (second USB, HDD)
- Bug new Kernel - no USB detected - reboot Azbox
- clean umount before rebooting
- Improve Azbox search function
- add NL end user guide
Download:
---------- Post added at 11:48 ---------- Previous post was at 11:43 ----------
AzBox Enigma 2 PackerĀ® by telesatĀ®
This tool is maded for all teams which would like to pack their Enigma 2 for AZBox HD Receivers.
Idea is that every team can sign their image, and give essential informations like : Team name, Image version and so on.
In application You have choice to pack :
1. E2 Files + Kernel
or
2. E2 Files
or
3. Kernel
Fields in AzBox E2 Packer which You can fill :
ID Team : Name of Team
ID Enigma : Name of Enigma Image
Version: Version of Enigma 2 Image
About E2: Something About Enigma 2
Kernel Descr: Like kernel version used in E2 ver.
Result of packing will be flashable patch.bin file with Your team Enigma 2 for AzBox HD devices.
NOTE: Images packed with this Packer by telesat, would be possible to flash in AzBox HD with new ,upcoming AzUP application from telesat.
Download:
