Tutorial:- NewCS & CCcam Config Creator
Tutorial:- NewCS & CCcam Config Creator.
Here's a little tutorial on how to use the NewCS CCcam Config Creator in 'Simple Mode'. This is based on version 0.6.1 and will create a working Sly UK config for the internal reader.
1. Start the program.
2. Select Sly UK from the 'Use Preset' box and select your DM model.
This now displays the Boxkey generator section because you'll need it !
3. Enter the Serial Number from your original Sly UK digi box. You will find this in the hidden engineers menu. To access this enter on the remote, Services, 4, 0, 1, Select.
Or you can enter the 17 digit code from the sticker on the bottom / back of the box. Be sure to enter the correct number in the correct box.
4. Now click Create Box Key.
5. Now you have a boxkey you can Click Generate newcs.xml
You are prmoted with the settings you have selected. If they are correct click Yes to continue.
6. You are now asked where to save the newcs.xml on your PC.
7. When complete you'll see this message to confirm what you've done.
8. Back on the main form you'll now see the util has remebered where you saved your newcs.xml and the FTP transfer button is now available.
9. Now you can continue and make your CCcam.cfg
Again you are prompted to check the details and continue by pressing Yes.
10. As before navigate to where you want to save your CCcam.cfg on your PC.
11. When complete you'll return to the main form. Now you'll see both options are available to FTP your files to the Dreambox.
12. Use the Transfer newcs.xml and Transfer CCcam.cfg buttons to put the files you've made onto your Dreambox. They will be FTP'd to the correct locations based on your Dreambox model selected.
13. You've finished. Goto your Blue panel and start NewCS / CCcam.
Dreambox Config Creator 0.9.3
Latest Version.
Change Log :-
Fixed a bug in the Boxkey conversion routine when using 17 digit serial number.
Minor changes to the installer.
---------- Post added 05-01-11 at 00:09 ---------- Previous post was 04-01-11 at 23:33 ----------
Am revenit si cu ceva poze
