Openbox S9 HD Twin Tuner PVR
New Model: OpenBox S9 HD PVR Twin Tuner
Specifications
HD set top box, openbox s9 hd twin tuner satellite receiver, pvr, internet sharing, cccam, linux, digital satellite receiver
*Product Name:
HD DVB-S2 hd digital satellite receiver with supporting CCcam network sharing, Common Interface, Smart Card Reader, HDMI output
*Main Function:
*The powerful HD receiver with Ali M3602 Chipset, support Linux Operating System, DVB-T\ DVB-S2 tuner available, have the similar function with dreambox 800HD, and can be used all over the world;
*Support CCcam, Newcam, GMcamd network sharing;
*With the PVR recording program function and software upgrade by USB2.0 port;
*Support popular decode: MPEG1/2/4, AC3, H.264 etc
*Basic Function:
Support Linux Operating System,
Support 1080i/720p/570p/576i/480p;
Support DVB-S/S2 digital TV signal modulated in QPSK/8PSK/16APSK;
SCPC & MCPC receivable from C/Ku band satellites;
Support USB 2.0 PVR. MP3, JPG photo playback
Support Electronic Program Guide(EPG) for 7 days;
Support software upgrade through USB2.0 port;
NIT search supported;
Support MHEG-5;
Support HDMI 1.3;
Teletext and subtitle out through OSD;
Support multi-lingual DVB subtitle and teletext;
Automatic and manual channel scan options;
Powerful program management function, parent lock;
MPEG-2 / H.264 Hardware decoding
Tuner Module, Plug&Play
Channel-change time < 1 second
Automatic service scan
Directly bouquet-lists
OSD in many languages and skin-support
Videotext Decoder
*Chipset and Memory:
CPU: 396MHz
Flash: 4Mbytes
RAM: DDR2-1Gbit
*Interface:
1x LNB In, LNB Out
1x HDMI
3x Video Component (YCbCr)
1x RCA Video
1x RJ45
1x USB 2.0
1x Optical S/PDIF
2x SCART
1x RS232
*Tuner:
Input Frequency:950~2150MHz
Loop Out Frequency:950~2150MHz
Input Level:-65~-25dBm
Input Impedance:75¦¸
LNB Power: Auto/14v/18v/OFF, Imax = 500mA
*Demodulation:
Demodulation: QPSK / 8PSK/ 16APSK
Symbol rate: 1.5~45MSPS
*DiSEqC:
DiSEqC Control: DiSEqC 1.0, 1.2, 1.3(USALS)
22K Tone Frequency: 22±1KHz; 0.5±0.2V
*Video Decoding:
Video Compression MPEG-2 and MPEG-1 compatible, H.246/AVC
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Video Resolution: 480i, 480p, 576i, 576p, 720p, 1080i
*Audio Decoding:
Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3, WMA, AAC, AC3
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
*Power:
Input power: AC100~240V 50/60Hz
Maximum Power consumption: ≤10W
*Accessory:
Remote control, AV cable, user manual
