HTPC: " ASRock 3D Vision "
pentru cei interesati de un sistem HTPC:
oare daca ii punem si un sistem DVB prin USB, ce dracie iese?
ASRock 3D Vision
CPU
- Intel® Core™ i5-460M Mobile Processor
- Support Intel® Core™ i7 / i5 / i3 Mobile Processor Family
OS
- Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
*Due to VGA driver limitation, 3D function only supports Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit.
Chipset
- Mobile Intel® HM55 Express chipset
Memory
- 2 x 2GB DDR3 1066MHz
- Support DDR3 1066MHz, 2 x SO-DIMM slots, Max. up to 8GB*
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
VGA
- NVIDIA® GeForce GT425M Graphics, NVIDIA® 3D Vision Capable
HDD
- 500GB, 7200 rpm
- Support 2.5" SATA HDD
ODD
- BD Combo
Front I/O- 2 x USB 3.0
- 1 x MIC
- 1 x Head Phone
- 4-in-1 Card reader (MMC/SD/MS/MS PRO)
Rear I/O- 1 x HDMI-1.4a
- 1 x DVI-I
- 5 x USB 2.0
- 1 x S/PDIF
- 1 x eSATAII*
- 1 x USB 3.0
*For eSATA function, Hot Plug function is supported in AHCI mode only. IDE mode does not support Hot Plug function.
LAN
- Gigabit LAN
Sound
- 7.1 CH HD Audio with THX TruStudio Pro™
WiFi
- 802.11b/g/n
Remote Controller
- MCE Remote Controller
Power Unit
- 90W/19V Adapter
Dimension
- 200mm(W) x 70mm(H) x 200mm(L)
Volume (liters)
- 2.8L
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
