New VTi "Vu Team Image - V 2.1 OE 1.6 -02.10.2010
Enigma 29/09/2010
Driver 9.27.2010
Plugins 29/09/2010
Skins 09/29/2010
Changes in the image:
Own Boot Logo's new radio and fashion logo.
various adjustments to the image and diffs and links from / usr / keys and / var / keys in the image and other minor things.
Vu Duo
LNB power is switched off in standby
Remote control response times improved
Video Event problem solved
VFD display problem fixed
Long press Fix
Virtual Tuner Problem Fix
Support for the integration fancontrol Race (duo)
Support for PCM sound in DD downmix mode
Diseqc problems solved
Scroll wheel problems fixed (duo)
Several GCC versions 4.4.3 - 4.4.1
Black screen when switching
Tuning algorithm improves
Support for other formats MKV
Partly occurring "no audio" problem solved
Solve the "late play audio" problem
Support of EOS detection in playback driver
Fix the mp3 playback problems
Support of the FF trick mode during playback
Memory management improved (solo)
Support for DTS pass-through (solo)
Fix vTuner frontend info
Tuning problem solved (solo)
By VTi Team
VTi panel (blue button)
Multilingual: English, German, Dutch
Tapping the blue button opens the VTi panel, a longer press the plugin menu
Improved multi-boot support (for BA and other tools)
Improved detection of internal SATA hard drives
Various adjustments Enigma2
Cron jobs are fully supported
A password change does not generate any additional messages more
Pure music CDs can be played eg by exteren USB drive
Optimerungen the kernel and system
Support of the form QT OE1.6 current web browser
Numerous improvements in network inter alia for the network browser plugin (improved access to shares)
Untersutzung of Windows 7 when Samba (CIFS) server
Support of the form Vu solo and duo with Image Backup (USB / NFI) / Restore Fix OE1.6
New Enigma2 Crashlogremover
Also swap file / media / usb
The IPK installer will also under / media / usb / * after IPK files and installs them automatically installed after the installation of internal flash directory / tmp.
The Software Manager plugin is now included in the fixed image
EPG integrated
Fix fancontrol attitude problem after restart
Diverse Wireless Fixes
Support for USB card readers with FTDI Chipset (Smargos, Easymouse2 etc.)
Green Screen Fix, if you have not installed and color Softcam keys to be confirmed
New Skin Infobar / render file
Softcam launched is displayed in the info bar
Improved MyTube, etc. MetacafeDirect support.
download:
usb
flash
