1.MAIN FEATURES
1) .ethernet port / Cccam/ Universal CA/ PVR and Scart / USB/ HDMI
2) .Supporting both HD and SD channels. Linux System.
3) .Digital Satellite Single Tuner. USB2.0 for software update (Later update for recording function).
4) .Ethernet for card sharring function Supporting CCcam protocol to connect all the server of Dreambox.
5) .Low Power Consumption (-0.8W in standby for Europe).
2.BASIC FEATURES
1) DVB-S2 and DVB-S fully compliant
2) MPEG-2 MP@HL Video Decoder
3) MPEG-4 AVC/H.264 HP@L4 Video Decoder
4) USB 2.0 PVR ready via external HDD or USB flash drive with time shift
5) Record and playback functions
6) MP3 player and JPEG viewer via external HDD or USB flash drive (memory stick)
7) Software and channel list download via USB 2.0
8) Multi-format Audio Decoder
9) High Definition and Standard Definition
10) HDMI output (576p / 780p / 1080i)
11) Format resolution: 1080i, 720p, 576p
12) DisEqC 1.0, 1.2, 1.3, USALS
13) RS232 or USB2.0 for software updating
14) User friendly OSD and easy operation
15) Auto Diseqc Function
16) 7 Days EPG
17) Teletext and Subtitle supported
18) Multi-language Menu
19) Sorting function and Timer function
20) 7 Favorite Group and Parental control function
21) 1 Scart (RGB support if required)
22) S/PDIF (Optical) output
23) Ethernet for sharing the server of Dreambox
24) Directly bouquet-lists
3.SPECIFICATIONS
Main System Resource
Decoder chip:NXP PNX8735
Flash Memory:1G bits
SDRAM:1G bits
Tuner:SHARP
DVB-S2 Input Frequency:950~2150MHz
Loop Out Frequency:950~2150MHz
Input Level:-65~-25dBm
Input Impedance:75¦¸
LNB Power: Auto/14v/18v/OFF, Imax = 500mA
Video decoder Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output digital Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Video parameter Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart Output: FBAS, RGB, S-Video
Serielle Interface RS 232 Typ RS232 bidirectional
Bit rate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet 10/100 MBit compatible interface
USB 1 x USB 2.0 Host ,PVR
LNB power and polarisation per tuner LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position DiSEqC 1.0/1.1/unicable/1.2
DiSEqC - Rotor Control
External PSU Input:110-240V AC / 50-60Hz / 0,6A
Output: 12V = / 3,0A
Physical specification Ambient Temperature +15 °C...+35 °C
Humidity < 80%
Size (W x D x H): 300 mm x 220 mm x 56 mm
Weight: 1,8 kg without HDD
