Dolce + phoenix in oscam
card : dolce
scule : dm800-clona -GP5.0- CCcam 2.1.4/oscam0.99.4
cititor : [Only registered and activated users can see links. Click Here To Register...]
setari :
-cititor : pe phoenix mode - alimentare 5v - freq. : 3,57
-oscam:
-oscam.conf :
[global]
LogFile = stdout
MaxLogSize = 102400
Sleep = 0
FallbackTimeout = 2
ClientTimeout = 5
ClientMaxIdle = 120
CacheDelay = 150
WaitForCards = 1
PreferLocalCards = 1
# logging
pidfile = /var/run/oscam.pid
logfile = /var/log/oscam.log
usrfile = /var/log/oscamuser.log
cwlogdir = /var/log/cw
[monitor]
Port = 988
NoCrypt = 192.168.1.1-192.168.1.250
AULow = 120
MonLevel = 2
[newcamd]
port = 15000@92f:000000
oscam.server :
#readerconfiguration
[reader]
label=Dolce
protocol=mouse
detect=CD
#Detect= RING
device=/dev/ttyUSB0
group=1
emmcache=1,1,2
Fallback= 0
CAID = 92F
IDENT = 000000
oscam.user :
[account]
user = test
pwd = test
group = 1
uniq = 1
monlevel = 0
caid = 92f
IDENT = 000000
CCcam.cfg :
N: 127.0.0.1 15000 test test 01 02 03 04 05 06 07 08 09 10 11 12 13 14
log din oscam:
>> OSCam << cardserver started at Sat Jan 1 01:00:47 2000
2000/01/01 1:00:47 735 s version=0.99.4svn, build #2967, system=mips-tuxbox-linux
2000/01/01 1:00:47 735 s max. clients=29, client max. idle=120 sec
2000/01/01 1:00:47 735 s max. logsize=102400 Kb
2000/01/01 1:00:47 735 s client timeout=5000 ms, fallback timeout=2000 ms, cache delay=150 ms
2000/01/01 1:00:47 735 s shared memory initialized (size=497450, fd=5)
2000/01/01 1:00:47 735 s auth size=4772
2000/01/01 1:00:47 735 s services reloaded: 0 services freed, 0 services loaded
2000/01/01 1:00:47 735 s userdb reloaded: 0 accounts freed, 1 accounts loaded, 0 expired, 0 disabled
2000/01/01 1:00:47 735 s signal handling initialized (type=sysv)
2000/01/01 1:00:48 735 s oscam.srvid loading failed, old format
2000/01/01 1:00:48 735 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
2000/01/01 1:00:48 735 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
2000/01/01 1:00:48 735 s 0 lengths for caid guessing loaded
2000/01/01 1:00:48 735 s monitor: initialized (fd=10, port=988)
2000/01/01 1:00:48 735 s camd 3.3x: disabled
2000/01/01 1:00:48 735 s camd 3.5x: disabled
2000/01/01 1:00:48 735 s cs378x: disabled
2000/01/01 1:00:48 735 s newcamd: initialized (fd=11, port=25000, crypted)
2000/01/01 1:00:48 735 s CAID: 092F
2000/01/01 1:00:48 735 s provid #0: 000000
2000/01/01 1:00:48 735 s cccam: disabled
2000/01/01 1:00:48 735 s radegast: disabled
2000/01/01 1:00:48 735 s logger started (pid=739)
2000/01/01 1:00:48 735 s Resolver thread started
2000/01/01 1:00:48 735 s http disabled
2000/01/01 1:00:48 735 s reader started (pid=741, device=/dev/ttyUSB0, detect=cd, mhz=357, cardmhz=357)
2000/01/01 1:00:48 735 s waiting for local card init
2000/01/01 1:00:51 741 r01 card detected
2000/01/01 1:00:51 735 s init for all local cards done
2000/01/01 1:00:51 735 s anti cascading disabled
2000/01/01 1:00:51 735 s dvbapi: dvbapi disabled
2000/01/01 1:00:55 741 r01 ATR: 3F FF 14 25 03 10 80 41 B0 01 69 FF 4A 50 70 00 00 5A 4A 01 00 00
2000/01/01 1:00:57 741 r01 Maximum frequency for this card is formally 5 Mhz, clocking it to 3.57 Mhz
2000/01/01 1:00:58 741 r01 [videoguard2-reader] ins36 returned unknown type=0x7F - parsing may fail
2000/01/01 1:00:58 741 r01 [videoguard2-reader] type: VideoGuard, caid: 092F, serial: 001F510F, BoxID: D1xxxxxx
2000/01/01 1:00:58 741 r01 [videoguard2-reader] ready for requests
2000/01/01 1:00:58 741 r01 [videoguard2-reader] card detected
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 0067, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 0078, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 0097, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 0098, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 00a0, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:58 741 r01 [videoguard2-reader] tier: 00c8, expiry date: 2003/10/09-00:00:00
2000/01/01 1:00:59 741 r01 [videoguard2-reader] tier: 0ff3, expiry date: 2003/10/09-00:00:00
2000/01/01 1:01:04 735 s client(1) connect from 127.0.0.1 (pid=789, pipfd=16)
2000/01/01 1:01:04 789 c01 encrypted newcamd:15000-client 127.0.0.1 granted (test, au=0)
2000/01/01 1:01:04 789 c01 user test authenticated successfully (CCcam)
2000/01/01 1:01:04 789 c01 AU disabled for user test
2000/01/01 1:01:25 789 c01 Connection closed to client
2000/01/01 1:01:25 789 c01 test disconnected from 127.0.0.1
2000/01/01 1:01:26 735 s client(1) connect from 127.0.0.1 (pid=841, pipfd=16)
2000/01/01 1:01:26 841 c01 encrypted newcamd:15000-client 127.0.0.1 granted (test, au=0)
2000/01/01 1:01:26 841 c01 user test authenticated successfully (CCcam)
2000/01/01 1:01:26 841 c01 AU disabled for user test
2010/08/31 13:19:02 841 c01 test (092F&000000/007D/5F:7288): found (165 ms) by dolce ()
2010/08/31 13:19:15 841 c01 test (092F&000000/007D/5F:6988): found (157 ms) by dolce ()
2010/08/31 13:19:28 841 c01 test (092F&000000/007D/5F:3DB0): found (146 ms) by dolce ()
2010/08/31 13:19:41 841 c01 test (092F&000000/007D/5F:60CC): found (155 ms) by dolce ()
2010/08/31 13:19:54 841 c01 test (092F&000000/007D/5F:2EAB): found (156 ms) by dolce ()
2010/08/31 13:20:07 841 c01 test (092F&000000/007D/5F:CADA): found (158 ms) by dolce ()
2010/08/31 13:20:16 841 c01 test (092F&000000/007E/5F:D19B): found (133 ms) by dolce ()
2010/08/31 13:20:18 841 c01 test (092F&000000/00E8/5F:208B): found (155 ms) by dolce ()
2010/08/31 13:20:24 841 c01 test (092F&000000/00E8/5F:786E): found (160 ms) by dolce ()
2010/08/31 13:20:34 841 c01 test (092F&000000/00E8/5F:EF11): found (165 ms) by dolce ()
2010/08/31 13:20:44 841 c01 test (092F&000000/00E8/5F:325A): found (151 ms) by dolce ()
2010/08/31 13:20:54 841 c01 test (092F&000000/00E8/5F:3820): found (161 ms) by dolce ()
2010/08/31 13:21:04 841 c01 test (092F&000000/00E8/5F:9FCB): found (161 ms) by dolce ()
2010/08/31 13:21:14 841 c01 test (092F&000000/00E8/5F:223E): found (144 ms) by dolce ()
Bravo ai reusit päna la urma felicitari
Care era problema de nu citea smargoul tau ?
clona are 2 porturi usb in spate :
-jos /dev/ttyusb0 - asa corespunde la mine ;
-freq default a acestui reader este 3,57mh , daca nu am pus asa in cfg nu a vrut -sau mai exact daca freq pe care e setat nu e la fel cu cea din cfg nu merge -.
oricum :cheers:
