Ca sa vedeti ce suport meserias au cei de la Azbox, am inclus aici o conversatie purtata cu ei prin email (cel mai nou raspuns e sus, ca e copiat din inbox).
Numele si adresa de mail au fost comentate ca sa nu ma umplu de spam.
Noroc ca pana la urma am reusit sa rezolv problema, ca daca te bazezi pe cei de la azbox... ....
Pacat, Azbox e o scula buna, dar oamenii care o fac n-au nici un simt al comertului.
Eu:
There has to be a solution. I will send it back to the supplier who will send it back to you then.
Best regards.
Azbox:
Dear xxxxxxx,
We are sorry but we don't have any information about it.
Hello,
I had this problem in this spring, I've sent back the receiver to azbox and got fixed. Now, after a couple of updates (all were succesful, without an error) the problem returned. No encrypted channel is displayed.
Yes, the smartcard is active and is working in another receiver.
If I start Multicas from telnet, what happens is that after MultiCas initalizes the card, there is no more debug info displayed on the console. (below is the output of multicas). When it was working, It displayed information regarding EMM/ECM's received and channel change messages. Now nothing is displayed.
I've tried to insert the smartcard in an another receiver (a dm500) and share it via Gbox/CCcam (to test if the cardreader is the problem - unlikely, because card_slot.info detects that card is properly detected ). It was not working. I've also tested with mgcamd. Same result.
I've replaced the current firmware (azbox-0.9.5006-patch.bin) with the old one which was working ( azbox-0.9.4991-patch.bin) but the problem remains the same. I also did a factory reset.
What is the problem and how can I fix it ? Why aren't any EMM's sent to MultiCAS any more ? Because this must be the problem. The emulator is not even aware that it has to decrypt the channel.
If you want more details (like serial nr.) please tell me all the info because I'll be at home in the weekend and I'll collect all the data you need.
Here's the info in files:
ccc_ecm.info contains Unable to retrieve ECM information all the time.
card_slot.info:
Card Name : Viaccess
Card Address : xxxxxxxxxxxxxxx
[ TVR 1 ] 2009.12.14~2010.12.14
[ TVR 2 ] 2009.12.14~2010.12.14
Using MultiCAS v1.62E-A07 - have tried older versions too.
Here's the output of Multicas:
AZBox[MultiCAS]$ ./emu_module
[EMU_MOD] main: Init Key
Open 1st [at EMU] :: ok..
DefaultKeyDate :: Date 200100405
emu_all_ktbl->KeyDate :: Date 200100405
UpdateAllKeyFlash2Ram :: Date 20100405
Viaccess MAX Index = 88
SECA MAX Index = 22
Irdeto MAX Index = 115
NAGRA MAX Index = 100
CrytoWorks MAX Index = 64
Conax MAX Index = 4
BISS MAX Index = 116
Open 1st [at EMU] :: ok.. -/EMU/OpenXCAS/MultiCAS/card_key.bin-
Define_CardKey_date :: Date 20090806
CARD_Key_Data->CardKeyDate :: Date 20090806
>> NAIrd_Act = 0
>> NAEmmU_f = 1 | NAEmmS_f = 1 | NAEmmG_f = 1 || NAAutoRoll = 1 || ActiveBlocker = 0
Open 1st [at EMU] :: ok.. -/EMU/OpenXCAS/MultiCAS/Data9F.bin-
Open 1st [at EMU] :: ok.. -/EMU/OpenXCAS/MultiCAS/splitterdata.bin-
>> Server-IP : 0.0.0.0 [Port = 3000]
>> LS_Mode = 4 | LS_Timeout_for_Recvfrom = 4 | LS_Sequence = 0 || LS_ClientIP_Count = 0
>>>>>>>>>>> Can't open prio-cfg file..
>> Prio_caid_ready = 0
[EMU_MOD] main: Init ecm/emm module
[EMU_MOD] main: Start EMU Module
Skip This line.. by # ..
>>>>> Disable_CardReader = 0
>>>>>>>>>>> line_str[12] : [splitter]
>>>>>>>>>>> line_str[19] : IP = 1.10.100.001
>>>>>>>>>>> line_str[13] : PORT = 3000
>>>>>>>>>>> line_str[22] : DN = Test.dyndns.tst
>>>>>>>>>>> line_str[2] :
>>>>>>>>>>> line_str[31] : CCCAM_NEWCAMD_WORK_TOGETHER = 1
>>>>>>>>>>> Can't open ignore list file..
[OPENXCAS_MOD] main: Start EMU Module(WORKING DIR = /EMU/OpenXCAS)
[OPENXCAS_API:Mon Aug 2 15:23:05.474] load_xcas_control:98 ## loaded controller ID = 0x19760507
osdep_msq_server_open : key_request 0x42E0AC94 key_response 0x42E0AC95
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
osdep_msq_client_connect : key_request 0x42E0AC94 key_response 0x42E0AC95
[EMU_MOD] main: Init SmartCard :: Disable_SmartCardReader = 0
Init for CCcam.........[CCcam_1st_Init=0]
>>Ext_ver_build = 3
CCcam :: OK Check_VersionBuild_for_cfg-EXT_Version
CCcam :: OK Check_VersionBuild_for_cfg-EXT_Build
CCcam :: connect[0] ret = 0
CCcam :: login succeed[0]
CCcam_login :: ret = 1 || serverx = 0
>>Ext_ver_build = 3
CCcam :: connect[1] ret = -1
CCcam :: connect failed
CCcam_login :: ret = 1 || serverx = 1
>>Ext_ver_build = 3
CCcam :: connect[2] ret = 0
CCcam :: login succeed[2]
CCcam_login :: ret = 1 || serverx = 2
>> Skip CCcam_login By Disable CCCAM_Active[03]=0
>> Skip CCcam_login By Disable CCCAM_Active[04]=0
>> Skip CCcam_login By Disable CCCAM_Active[05]=0
>> Skip CCcam_login By Disable CCCAM_Active[06]=0
>> Skip CCcam_login By Disable CCCAM_Active[07]=0
>> Skip CCcam_login By Disable CCCAM_Active[08]=0
>> Skip CCcam_login By Disable CCCAM_Active[09]=0
>> Skip CCcam_login By Disable CCCAM_Active[10]=0
>> Skip CCcam_login By Disable CCCAM_Active[11]=0
>> Skip CCcam_login By Disable CCCAM_Active[12]=0
>> Skip CCcam_login By Disable CCCAM_Active[13]=0
>> Skip CCcam_login By Disable CCCAM_Active[14]=0
>> Skip CCcam_login By Disable CCCAM_Active[15]=0
[EMU_CTRL] main: OK got MyIP :: Init_CCcam ret=1
newcamd: All NEWCAMD_InActive to Connect to server
[EMU_CTRL] main: OK got MyIP :: newcamd_all_log_in ret=1
-->Start init_sc_main()...
init_sc_main::Default stack size = 2093056
init_sc_main::Creating threads with stack size = 3000000 bytes
sc_card[0].opened = 0xFFFFFFFF[-1]
-->sc_main_Tid = 0x5015 [20501]
sc_main_thread: stack size = 3000000 bytes
SamrtCard Open OK :: 8
-->>> Cold Reset :: sc=0
card_mode_reset reset_status = 1
Smart Card is inserted..
--> CARD_INSERTED...
Start Smart Card is initialized
Found ATR length = 12
--> CARD_INIT_OK...
[EMU_CTRL] main: START_SMARTCARD(sc = 0)
card_set_param param_status = 2 || Mode = 2[0x02] || O.C. = 0
>>>>>> io_err_count_dbg = 0
>>>>>> Start ------ at Mon Aug 2 15:23:10.113
[EMU_CTRL] main: sc_card[0].casystemid = 0x0500
[EMU_MOD] card_in_out_controll: In_Out = 1 [Stream_id = 0 || Sequence = 65535]
[EMU_MOD] Take_ecm_pid_for_Card: SteamID = 0 | Card = 0 | pCard_CAS_id = 0x500
[EMU_MOD] Take_ecm_pid_for_Card: Mode = 0
[EMU_MOD] card_in_out_controll: CARD:: Stream_id = 0, ECM_PID = 0x1fff, SYSTEM_CAS_ID = 0xffff
After this no more messages are displayed about EMM/ECM.
Sent: Monday, August 02, 2010 5:12 PM
To: xxxx
Subject: Re: [Ticket#xxxxxxxxxxxxxxxxxxxxxxx] no EMM/ECM
Dear xxxxxxxxxxxxxxxxxxxx,
Did your Smart Card works or not? Please, explain us your problem.
Best Regards,
Your Support Team
08/02/2010 10:00 - ......... wrote:
De: xxxxxxxxxxxxxxxxx [[Only registered and activated users can see links. Click Here To Register...]
Assunto: no EMM/ECM
Hi.
I'm writing here again because on your forum my post doesn't get posted.
Here's the problem:
I own an azbox elite HD receiver, for almost a year.
Last december, I had a problem with it, after an update, basically, MultiCAS or any other card reader plugin was not aware of the channel change, and did no EMM/ECM and the channel remained scrambled (I have a valid smartcard that does the decoding). No application format/reversion back to old firmware solved the problem.
I ended up sending back the receiver to satmultimedia from Romania, who sent it back to you. The receiver got fixed. Now, after a couple of months later, after a couple of FW updates the same problem returned. What should I do ? I don't want to send it back again because it costed me almost 1/4 of the money the receiver costs, and sending back every time the FW fails is not a viable solution to me.
Maybe you have encountered the same problem with other receivers too, could you tell me how can I fix it ?
Regards
