Salut imi poate spune cineva mai multe despre placa asta? a avut cineva? Cum se comporta?
SKY2PC DVB Satellite Data & Digital TV
[Only registered and activated users can see links. Click Here To Register...]Code:• RF tuner input F-type female
• RF frequency 950–2150 MHz
• Input power range -60 to 10 dBm
• Impedance 75 Ω
• Power dissipation 600 mW
• Demodulation QPSK
• Input symbol rate 2-45 Ms/s
• Viterbi code rate 1/2, 2/3, 3/4, 4/5, 5/6, 6/7,
7/8 (auto sense)
LNB Control
• Supply voltage 13/18 V for DVB
11/15 V for Japan
software switchable
• LNB Current limit 0-400 mA
• LNB power control
software ON/OFF
• Tone switching 22 kHz for DVB
44 kHz for Japan
• DiSEQ 1.0, 1.1
Conditional Access
• Descrambler DVB Common descrambler
Multi-2 descrambler
• Fixed key CA
• Embedded CA
• DVB Common Interface (CI)
Minimum System Requirements
• Pentium II 300 MHz or Celeron 366 MHz
processor or greater
• Windows 98, NT 4.0, 2000, CE or ME
operating system
• 64 MB RAM
• 10 MB Hard disk space available
• 1 available PCI slot or USB port
• Analog modem (56K/V.90 recommended)
Data Streams
• Bandwidth Up to 100 Mbps sustained.
Any number of high or
low-speed channels.
• SCPC or MCPC
• Transport demux On-demand FlexParser™
PID filtering
MAC filtering
IP unicast filtering
IP multicast filtering
Section packing
• Compliance ISO/IEC 13818-1
ISO/IEC 13818-6
EN 301 192
Audio/Video Decoding
• Video decoding ISO/IEC 13818-2
MPEG-2 MP@ML
•Audio decoding ISO/IEC 13818-3
MPEG-1/2 layer 1&2
•Teletext ETS300 706
DVB/VBI
Host Interface
• PCI version 2.0
32-bit master DMA
ACPI compliant
133 MB/s burst to host
• USB version 1.1
Upto 8 Mb/s
Operating Temperature
• 0–50°C [32–122°F]
Dimensions
• PCI 133 x 100 mm
• USB 140 x 110 x 24 mm
S k y 2 P C
