help: configurare Incumbus ca si client CCcam
Buna,
ar putea cineva sa-mi dea o mina de ajutor cu configurarea unui incumbus (ipbox 910hd) ca si client pentru un server CCcam (ubuntu cu card A_k-T*A in local) ?
Cu un DM si un clien CCcam reusesc sa citesc, dar cu IPBOX-ul nu reusesc.
Va atasez informatiile de configurare si mesajul din consola (debug nivel 3), poate aveti o idee sa-mi dati.
Multam,
Li
Mesaj consola
cuberevo:/var/bin# ./incubusCamd-0.95
Using config file: ./incubusCamd.conf
Using prio file: /var/bin/incubusCamd.prio
************** Starting log on Tue May 11 01:46:41 2010 **************
Configuration settings:
Box type: CubeRevoHD
Debug level: 3
Log output to file: Yes
No such file or directory: No such file or directory
Bad file descriptor: Bad file descriptor
STPTI_IOCTL_OPEN():Ioctl error
[PMT Proxy] Started successfully.
cam[di:-]: Ready.
cam[di:-]: Message data:
9F 80 32 4B 03 00 1F 03 00 3B 01 81 08 00 32 00
00 00 65 01 6E 82 02 01 00 84 02 00 D9 09 0F 05
00 FD 5D 10 01 00 13 01 20 14 03 02 2F 00 09 0F
05 00 FD 7E 10 01 00 13 01 20 14 03 02 4F 00 09
04 0B 00 FD 71 02 17 D5 00 00 04 17 D6 00 00
SID:0300, NS:00000000, TSID:0000, ONID:0000, PMT PID:0000, DM:1, DMX:0
Root CA Info | CA Descriptors: 0
cam[di:-]: Can't decode. CA info not found.
Fisierul incubusCamd.conf
cuberevo:/var/bin# more incubusCamd.conf
background_execution=0
debug_level=3
log_to_console=1
log_to_file=1
logfile_name=/var/bin/incubusCamd.log
softcamfile_name=/var/keys/SoftCam.Key
priofile_name=/var/bin/incubusCamd.prio
on_screen_messages_show=1
on_screen_messages_username=root
on_screen_messages_password=
on_screen_messages_key_update=0
on_screen_messages_wait_for_key_update=0
on_screen_messages_ecm=1
on_screen_messages_emm=1
console_logs_broadcast=0
console_logs_broadcast_port=666
webif=1
webif_port=1668
[Prov:000000:CaID:0000]
check_priority=cs,emu,card
cs_protocol_order=cccam,newcamd,gbox,camd35,camd33,radegast,aroureos
process_emms_on_cs_mode=1
process_emm_g=1
process_emm_s=1
process_emm_u=1
seca3_handler=1
#[Prov:000501:CaID:1833]
#check_priority=cs,emu,card
#cs_protocol_order=cccam,newcamd,gbox,camd35,camd33,radegast,aroureos
#process_emms_on_cs_mode=0
#process_emm_g=0
#process_emm_s=0
#process_emm_u=0
#seca3_handler=0
#chid=-1
[Servers]
cccam://ipbox:ipbox@192.168.1.5:34567
