AAF Recovery Tool UFS 910 V1.7
upgedatet am: 08.05.2010 20:06
Beschreibung:
Here are some pictures of my first AAF Recovery Tool.
I don't know if it's really needed but nonetheless you can comment it.
This is a recovery with a Null-Modem cabel and Network.
It will clean the bootargs sector and install FW 2.02RC with FTP-server.
No compilcated procedures, only a cable and a few click's.
I also added the default bootdesc_x for Mini/Maxi U-boot ( because after recovery they will be gone ).
And you can set your ip, serverip, mac and ....
Thanks to SoLaLa for the patience and the info (all the explainig ) !!!
V1.7
- add new Maxi Uboot (fix for 14w)
V1.6
- fix when crc starts with a zero
V1.5
- add picture of the UFS910
- add save comport
V1.4
- add flash E2 image (only visible when Maxi U-boot is installed)
V0.6
- remove animation timer
V0.5
- update Maxi U-boot 1.3.1 to r1.7
V0.4
- change layout and icons
V0.3
- add Mini U-boot install (r1.3)
- add Maxi U-boot install (1.1.3 r1.5)
- add Original U-boot install (1.1.2)
- add "search comports" button
V0.2
- fix gateway in default bootdesc
- remove check for mac: 00:00:00:00:00:00
V0.1
- first test version
NOTE:
1. you must have installed NetFrameWorks 2.0 or higher.
2. check your firewall for use of the Tftp (port 69 and random data port)
3. for windows Vista or windows 7 you must run it as administrator
4. make sure you have no other Tftp-server running on your pc
5. make sure the files in the AAF Recover Tool dir are accessible (read access)
