Primul test cu SIF E2 092b !
Asa cu deja s-a vazut din "release notes" ... versiunea nu aduce mari noutati ... sau nu sint din cele mai vizibile :
release 0.9.2b
FLASH only release
- fix for passwd on flash
- fix for wpa_supplicant.conf on flash
- added possibility to edit file /etc/ipkg/official-feed.conf
release 0.9.2
- fixed Polsat HD channels and many other HD channels (i.e.: Sky Calcio HD, Sky Olimpia HD and so on)
- updated kernel to version 2.6.23.17-0123
- added gdata for python plugins
- added romanian language (thanks to otheitis and his team)
- improved remote controller responses time
- made general OS system optimizations
- updated Enigma2 CVS to the 13/03/2010
- fixed USB booting for: cuberevo-mini-fta, cuberevo-250hd, cuberevo-2000hd (usb file system must be ext2 type)
- added wifi drivers (zd1211 chipset, if you need them do an insmod /lib/modules/zd1211b.ko)
P.S.: PIP is temporarily disabled.
For USB version boot (file system must be ext2 type): mkfs.ext2 -I 128 -b 4096 your_device
where your_device could be /dev/sdaX, /dev/sdbX, or similar.
Din teste singurul lucru cu adevarat vizibil este o reactie mai sprintena la
telecomanda ... lucru care devenise chiar enervant ! Intradevar , pentru cunoscatori , schimbarile
sint mai importante la nivel de organizare interna : serverul SIF devine activ ... are o intreaga lista
de plugin-uri ... ce pacat ca nucleul Enigma incepe sa consume un astfel de spatiu in Flash incat
mare lucru nu-ti mai poti permite. Cat depre stabilitate ... vorbim dupa teste mai aprofundate ! ...
aparent apar mici balbaieli pe care inca nu mi le explic ...
