Original Image Version 4.8
:clap::clap::clap:
Ver 4.8 Release note
Duo/Solo
1. Fix 4:3 video mode problem.
2. Turn off FAN at stadnby mode when there is no channel recording.(Duo only)
3. Fix udev problem.
4. Change mbox-dvb-modules.bb to download driver from vuplus server.
( ** All build trees are being moved to vuplus git server **)
5. Move kernel-module dependency to mbox-dvb-modules.bb from initscripts-mbox_1.0.bb
6. Clean up udev-static-devices
7. Internal test routine is added to e2
8. Fix framerate information(20100603 driver)
Solo
1. Change kernel configuration
2. Add ver 4.7 features
Changed Folders/Files.
Makefile-vuplus-4.8
./local/packages/enigma2/enigma2-2.8git20100129/enigma2_vuplus.patch
./local/packages/enigma2/enigma2-2.8git20100129/enigma2_vuplus_Vu_HD_skin.p
atch
./local/packages/mbox/mbox-dvb-modules.bb
./local/packages/udev/udev-124/mbox/init
./local/packages/udev/udev_124.bb
./local/packages/udev/udev-static-devices/bm750/udev_static_devices_tarball
./local/packages/udev/udev-static-devices/vusolo/udev_static_devices_tarball
./local/packages/udev/udev-static-devices.bb
./local/packages/initscripts/initscripts-mbox_1.0.bb
./local/conf/machine/vusolo.conf
./local/packages/initscripts/initscripts-1.0/vusolo/bootup
./local/packages/linux/linux-vusolo/linux-vusolo_dvb-core_fe.patch
./local/packages/linux/linux-vusolo/linux-vusolo_kojbect.patch
./local/packages/linux/linux-vusolo/linux-vusolo_romblock.patch
./local/packages/linux/linux-vusolo/vusolo_defconfig
./local/packages/linux/linux-vusolo.bb
Cine vrea sa actualizeze Originalul 4.7 / VTI 1.1
driver 4.8 se pune in
/lib/modules/2.6.18-7.3/extra/
Original Image Version 5.4 - Vu+ Duo
This Release Includes:
- Fix wrong video size/framerate information
- Upgrade Linux DVB API driver to version 5(can be used with latest E2)
- Change dvb-core to use v4l-dvb(with additional patch)
- Change LED Color at standby(solo)
- Support vtuner at solo
- Fix vtuner audio/video sync problem
- Clean up and fix misc. bugs at vtuner driver
- Fix USB transfer problem when both front and rear ports are in use simultaneously (solo)
- Disable HDMI hotplug at standby
Vu+ DUO Original Images version V5.6
New official version V5.6
Open Embedded
- Fix HDD Detection problem at bootup
- Speed up screen capture
- MediaPlayer related libraries update.
- Update e2 to the latest version.
- Relocate the fb.ko to its original postion.(fb.ko remains for backward
compatibility)
- For other details, please take a loot at git log.
Driver update
20110113
- Support PIP(I-Frame only, duo)
- TS playback improvement(fix bogus error message)
20110114
- Fix PIP problem(Support all video modes, duo).
- Fix PIP and OSD overlap problem(duo)
20110208
- Support accelerated graphic fill
- Enhance PIP stability(duo)
- Support dvb api ver. 5 at vtuner driver(DVB-S2 support)
- Recording improvement
