New E2 Katy Todo Dream Tuxer2 v0.1
That you may know that I will not forget or you or our dear Katy.
Thank Beor delivery in this forum, its spaces dedicated to house and your information.
PKT Team also thank for letting us use part of its extrapanel. Once we agree with the fellow Cali, we will have our own extrapanel, with downloads from our server, is a beautiful and very complete extramanel will be soon.
It is for USB.
"It incorporates all the emus to present day with their config files. NO files K E Y S
"It's another compilation of what I worked my best, codecs, libraries, modules, etc..
"The skin is in HD cams info and other particulars, and personalized with the colors of the forum, (the design is not mine, but I think you'll like).
-Skin and HD for the mediaplayer mediacenter, the latter must be touched up a tad.
-Incorporates all the plugins that are a day today, there will be any more than berve now you can download tododream server itself.
"I will create the swap 127Mg at first boot, you will see that the first time take a while to start.
"It recognizes all the video codecs there till now.
-Incorporates a ordenadita channel list, but the lists are very personal, you put it that you like.
Panel-mounting HDD or pens or whatever you please, remember that a hard drive plugged into the rear usb higher in the Penlan to mount serious "sdb1", once assembled and will forever unless you change it clear. Thus the label not you depend on the HDD or pen, drive and mount it as a point, regardless of label has. To tax in if you have to create you the famous movie folder.
-Recognize all formats including hard disk ntfs
-Funcienan subtitles perfectly, provided the documentary film or the broadcast.
"The plugin to download subtitles from a global database are they valid the epg of something being issued or to be given or any movie you have in the pc connected to the katy by cifs or nfs and sync.
"With the blue button, enter into the extra panel
Blue + Blue-Button you have several plugins, among which is the AC3libsinc, if pulsais in the top left of the TV screen you will sincronixar time for sound and vision and decompensation inthe case, you give him a left arrow or right of command.
Blue + Red-Button Media Center.
Weekly EPG
Many things and you know it, so I do not follow.
Tell them now and as you have mentioned, the most stable are the neutrino, is incredible as endure.
In this, as is happening at all at this time, sometimes you lose the sound, it's just finding the nonsense that produces it, but still happens.
You have the mbox 6 in its latest version (only for peers mbox) and mbox 5 (for mbox and gbox peers), remember that both the one and the other using the same configuration file name was the "mbox.cfg" however are not the same, I've done is rename it to mbox-6 and leave your name that is to mbox-5, to rename the mbox only read the one with the correct name, in this case is that you have for mbox5 (peers mbox, gbox and newcam). If you decide to use the mbox-6 (single peers mbox) renombrais the mbox.cfg there now with what you can think and mbox.cfg there with the name changed, as mbox.cfg dejais, so that at boot mbox-6 I read that.
I would appreciate knowing whether this E2, peers and pile them guiller channels work in HD and the rest will go to such stability.
This compiled with lots of love and humility for you, thinking more about stability than anything though I insist that as the neutrino nothing.
Chronic compñero If you have time and want to get a catch, would be greatly appreciated, he is a crack with this or if you want to go either.
channels, buquets, lamedb, etc.., go into / etc/enigma2 /
satellite file. xml, goes into / etc / tuxbox /
Enjoy
A greeting
Gracias a javier3034 y a tododream
Cum de nu merge h-h deloc?
Am pus imaginea pe stick bootabil, (pe Kathi am 1.06) , totul in regula, porneste frumos insa nu am semnal pe nici un post si vad ca nici motorul nu pare alimentat... Ceva solutii? Cum activez incubus? Poate trebuie sa schimb imaginea orig. sa pun un AAF 2.0e - insa nu e stabila, se blocheaza in hd si moare asa...
