Opticum HD 9600 - o placuta surpriza
Fara nici un dubiu Opticum HD 9600 este o surpriza placuta ! spun asta
pentru ca in gama low-end low-cost ... ne-am obisnuit sa nu prea avem
pretentii ... Opticum HD 9600 vine sa infirme aceasta ipoteza !
Ce este special ? simplu are o interfata ethernet ... evident ca nu
degeaba ! si asa cum este moda actuala stie sa se conecteze la un server
CCCam ...si o face chiar bine ! server bun stabilitate excelenta !
Meniurile sint simple, sobre, prea sobre chiar ! sint facute in HD ! asa
ca uitati ca are si un SCART ! merge dar meniurile ...nu arata grozav !
in schimb pe un LCD merge super! Telecomanda este usoara, ergonomica in
ton cu clasa receptorului. Cititorul de card este asistat de un sistem
MCAS ...evident de baza fiind Conax.
Se gaseste pe piata de aproape doua luni si a ajuns la o anume stabilitate
soft care-l recomanda ... il recomanda si pretul ..765ron.
General Data
Digital High Definition Satellite Receiver
SD / HD support (MPEG4 AVC/H.264),
2x Common Interface Slots,
2x Card Reader,
USB PVR Ready,
Timeshifting,
High Definition Video output: HDMI and YPbPr,
Front panel display – VFD,
Channel sorting by Satellite, Alphabetic order & Network FTA, CAS,
EPG: Now, Next events and 7 days schedule,
Subtitle support: OSD & VBI insertion for TV,
Variable Input Symbol Rate (1-45 Msps),
Video output resolution: 576p, 720p, 1080i,
Multi language OSD,
Fast Channel Change,
8 Favorite List & Unlimited Programs per each,
Channel Edit Function: Move, Delete, Favorite, Lock, Rename, Skip,
Manual PID/ Satellite & TP/ Network Scan,
S/PDIF (Digital Audio or AC3 stream out),
Unicable, DiSEqC 1.0, 1.1, 1.2 and USALS Compatible,
Software Upgrade via RS-232C & USB,
Ethernet connection Supported
CPU
Processor: STi7101
Flash memory: 8 MB
RAM memory: 192 MB
Satellite tuner / lnb
Input Connector: F-type, IEC 169-24
IF Input Frequency: 950MHz to 2150MHz
IF Loop Throughout
Input Level: -65 dBm~-25 dBm
LNB Power: 13 /18VDC / 500mA Max
DiSEqC Control: Unicable, 1.0, 1.2 & USALS compatible
Band Switch: 22KHz Tone(22 +/- 4KHz,Amplitude :0.6 +/- 0.2V)
Modulation method: LDPC/BCH(DVB-S2) 8PSK/QPSK, DVB-S QPSK
Symbol Rate: LDPC/BCH(DVB-S2) 8PSK/QPSK :10~30Msps
DVB-S QPSK : 1~45Msps
Decoding Rate 1/2,2/3,3/4,5/6 and 7/8
Bandwidth: 36MHz
LDPC/BCH: Punctured Code ,1/2,2/3,3/4,3/5,4/5,5/6,8/9,9/10 in DVB-S2
Front PCB
Display VFD or 7-Segment LED
Common Interface 1 (optionally 2)
Smartcard Reader 1 (optionally 2)
Rear panel
RCA Video, Audio L, Audio R, YPbPr
SCART TV
S/PDIF Coaxial, (optional optical)
HDMI 1.2
USB, IR Connector for external IR Sensor, RS232, Ethernet
Power supply
Input Voltage Free Voltage (100~250V AC, 50/60Hz)
Power Consumption 17 W max.
<1W in standby
