SWF-Vizyon-8x0/0-E2_V2.0_flash und USB
SAT - WORLD - FORUM
auf Basis TDT Tideglo V0.7.5
Das SWF präsentiert euch fur alle Viyzon-Boxen (800,810,820 und 8000)
unser neues Enigma2-Image.
Diese Image's laufen auch auf den IPBoxen!
Also viel Spaß mit dem neuen Enigma 2
release 0.7.5
- added possibility to search channels by channel name's first letter,just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connectother devices to the box and see automatically the TV signal whencuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in theA/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels(like Universal Channel with Romanian subtitles, TotalTV and so on:report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on somechannels (like Mega, Star, ANT1 in package Netmed: report if now itworks good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
SWF MOD :
- eigenes SWF-Panel
- Bootlogo geändert
- cardreader support
- swf-panel installierbar (script-executer)
- Enigma2.mo angepasst auf vizyon
- Telnet-login uberarbeitet (root / vizyon)
- Videotext auf Wunsch nun Vollbild
- png im Webinterface getauscht (webtv)
- Web-Interface Style geändert
- incubus 0.96, mbox , camd3 mgcamd sind bereits enthalten ( Blue Panel )
Danke an mcron und alle Tester
-User = root
-Passw.= vizyon
Download Vizyon 800 / NP-ULC/ 01.- Receiver / IP-Box - Cuberevo -Vizyon / 1.- Images / 07.- Vizyon 800 - IP-Box 91HD ( 250HD )
[Only registered and activated users can see links. Click Here To Register...].......... [Only registered and activated users can see links. Click Here To Register...]
Download Vizyon 810 / NP-ULC / 01.- Receiver / IP-Box - Cuberevo - Vizyon / 1.- Images / 08.- IP-Box 900HD ( Mini )
[Only registered and activated users can see links. Click Here To Register...]..........[Only registered and activated users can see links. Click Here To Register...]
Download Vizyon 820 / NP-ULC / 01.- Receiver / IP-Box - Cuberevo - Vizyon / 1.- Images / 09.- IP-Box 910HD ( Mini2, 3000HD )
Download Vizyon 8000 / NP-ULC / 01.- Receiver / IP-Box - Cuberevo - Vizyon / 1.- Images / 10.- IP-Box 9000HD
