Neutrino rotor settings (USALS)
Neutrino USALS gotoXX Motor settings
Pentru a seta antena am facut un mic ghid.
Apasam MENU
(Press MENU)
Service
Servicescan
Motor-Settings
Setam motorul si salvam, punctul il introducem cu sageata jos!
(Enter your location, latitude and longitude as for all USALS settings.
Pay attention to LaDirection and LoDirection)
Revenim in meniul anterior si intram la
Setup satelittes input /LNB
(You will have to set to ON the Gotoxy option for every satellite that you will use,
in the Setup satellites input/LNB list)
Alegem pe rand sateliti pe care ii vom seta
Punem in cazul motorului
USE gotoXX pe ON
Facem asta pentru toti satelitii si salvam
(set to ON the Gotoxy option for every satellite that you will use, and save)
