General Specifications
Standards: Annex A ANSI T1.413 Issue 2, ITU-T G.992.1 (G.DMT), G.992.2 (G.Lite), G.992.3 (ADSL2) and G.992.5 (ADSL2+), 802.11g/802.11b
Data Transfer Rate:
G.992.5(ADSL2+): Downstream rate up to 24M bit/s, Upstream rate up to 1M bit/s
Wi-Fi rate: 54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2 and 1M bit/s
External Interfaces:
WAN: One ADSL/ADSL2+ port (RJ-11)
LAN: Four auto-sensing 10/100 Base-T Ethernet ports (RJ-45)
One screw-on antenna for 802.11b/g wireless connection
Features:
Support routing and bridging functions
Built-in PPPOE/PPPOA dialing
Support NAT, NAPT, extended ALG, DHCP server/client, DNS relay, IGMP proxy and port mapping
Support powerful wireless network security, stateful packet inspection, Access control list, IP/MAC filtering, PAP/CHAP
Support remote/local upgrade through HTTP and TFTP
Physical and Environmental Specifications
Power Consumption: Max. 8 W
Operating Temperature: 0℃ to 40℃ (32°F to 104°F)
Humidity: 10% - 95%(non-condensing)
Dimensions: (L×W×H) 213.8 mm × 146.4 mm × 39.3 mm
Net Weight: 360g
LED Indicators: WLAN, LAN1-4, INTERNET, ADSL and POWER
250 ron cu transport inclus!!!
!!!! 230 ron....
super oferta!! 150 ron !!! (+posta)
inca e de vanzare ..sau schimb cu unlooper!!
