NEW!!! Dreamset v2.27
Dreamset is a settings editor for digital satellite receivers running Enigma 1, Enigma 2 and Neutrino Plus firmwares like DreamBox. Triple Dragon receivers are also supported.
You can use Dreamset to edit Settings of the following formats:
# Enigma-1
# Enigma-2(Satellite/Cable/Terrestrial)
# Neutrino NPlus
# Triple Dragon
Also Dreamset can open and import settings of the following formats:
# DGStation/Relook 200s/400s (dat)
# Nokia 9800s/9902s Files (m98)
# LyngSat script files (dat)
# SatcoDx(sdx)
# DVB (dvb)
# Humax (hnf)
Dreamset offers a user friendly interface with a plethora of usefull operations which make settings modification easier.
# Add,Change,Delete bouquets and favorite lists
# Reorganize services in bouquets and favorite lists
# Add,Change,Delete services,transponders,satellites
# Flexible User Interface, multiple selection and Drag & Drop.
# User defined Sorting of services in a list/bouquet and other sorting operations
# Multilanguage support for names(Unicode Support).
# Markers support.
# Clipboard Copy/Paste of lists,services,channels,transponders (you can copy.paste from one Dreamset to another)
# Import Favorite Lists from other settings like DreamBox,Nokia 9800,Humax.
# Convert settings to other supported formats.
# Multilanguage User Interface support.
# DreamBox configuration editor (advanced).
# Custom telnet and http commands
# Dreamset can minimized to tray, right cklick to Dreamset Icon popups a menu with basic operations
# Multibox Configuration, you can define more then one box and switch between them at once.
History ver v2.27 :
Added: When converting settings from Enigma2 to Enigma1, all non SD services and transponders are removed.
Fixed: Fix, minor parsing error in E1 & E2 settings
Fixed: Fix, set attributes to multiple services from list (popup menu)
Added: Two new options added for the setup of a connetction (Telnet usage/command). The porpose of these options are to cover the case where reload settings fail using HTTP request. You can setup whether or not you want to reload settings using a telnet command. If you do not enter a telnet command Dreamset uses for E1 "reboot" and for E2 "killall -9 enigma2"
