HOW TO : 2 SERVERS CCCAM in 1 PC/LAPTOP
More then 1 CCcam on same PC with differend nodeid
'' Its about more then one CCcam on 1 PC and i have to say i tested i just on a pc and not on a dreambox,
with in my case Ubuntu installed on it, but it works on more linux distro's , centos , debian and so on..
I did read a lot of requests on differend forums about more then 1 CCcam's on the same PC,
and because of everyone who was trying, had the same problem and that are that the CCcams running
on the same PC had the same NodeID.
When you do this you have to set differend ports for every CCcam!!
And i had some sparetime for my hobby anyway, so i took a shot at it and solved the problem.
First we have to name all the CCcam's like this CCcam_1.x86 and the config like CCcam_1.cfg and so on.
the .x86 is important or sometimes the cam's won't start. So don't change that if you want to use it.
the CCcam's starting is done like this. /usr/local/bin/CCcam_1.x86 -C /var/etc/CCcam_1.cfg
So now the trick, when i was testing i saw the same nodeid no big suprice because everyone did know that.
What happens is that when you start CCcam it writtes down the nodeid in /tmp/ like /tmp/.CCcam.nodeid
But when you start the second CCcam it takes over the Nodeid from CCcam that started befor.
so i thought what will happen when i delete the nodeid from the CCcam when it is running,
so i did and there was nothing changed CCcam was still running perfect without any problems so i started the second CCcam
and it had a new and differend nodeid so problem solved ! easy ??? yes !!
But when you have to start al the cam's al the time manualy then you have a big job, so i made some nice small
scripts to run it all easely to start, stop, check the cam's running and config updates.
Bud you have to make some new directory's
/var/cccamlog for the logfiles /var/scripts for the scripts and /var/config and /var/backup for the config files
the script makes a backup from the config befor the last changes.
in some scripts you have to fill in your username from the distro that you use. on the plases with ?????????
and what to do to remove the nodeid is the command :
chown yourusername /tmp/.CCcam.nodeid ----> to get the rights to remove the file.
Then the remove and start command:
rm /tmp/.CCcam.nodeid && /usr/local/bin/CCcam_2.x86 -C /var/etc/CCcam_2.cfg
and this you need to do for all the next to start CCcam's. i have tested it till 10 CCcam's just for fun.
the script are made easy to add extra lines colored in yellow for each extra CCcam you add.
all the Cam's and configs can be in the same directory's configs in /var/etc/ and the cam's /usr/local/bin/
a few things, each CCcam needs a differend CardReader but the CCcam,s can share the same *** files.
when you want to use moer Cccams then 3 you have to change some lines.
chmod 755 the scripts
to start the cam's from reboot from the pc ,set the line in /etc/rc.local :
/var/script/MoreCCcamstart.sh
and to use the configupdate script . you better do like this first stop the cam's compleet!
then do configupdate then start the cam's again and use thise times because of the check script.
crontab -e
56 03 * * * /var/script/MoreCCcamstop.sh
57 03 * * * /var/script/MoreConfigUpdate.sh
58 03 * * * /var/script/MoreCCcamstart.sh
*/5 * * * * /var/script/MoreCCcamCheck.sh
script name MoreCCcamCheck.sh
#!/bin/sh
#Script to check if the CCcam's are running.
#Script is written by Youknowhoo.
process=`ps auxwww | grep CCcam_1.x86 | grep -v grep | awk '{print $1}'`
if [ -z "$process" ]; then
echo "Couldn't find CCcam_1.x86 running.removing nodeid and Restarting CCcam Server" >> /var/cccamlog/cccam.check
echo && date >> /var/cccamlog/cccam.check
chown ??????? /tmp/.CCcam.nodeid
rm /tmp/.CCcam.nodeid && /usr/local/bin/CCcam_1.x86 -C /var/etc/CCcam_1.cfg
else echo "CCcam_1.x86 is still OK!" >> /var/cccamlog/cccam.check
fi
process=`ps auxwww | grep CCcam_2.x86 | grep -v grep | awk '{print $1}'`
echo "Couldn't find CCcam_2.x86 running.removing nodeid and Restarting CCcam Server" >> /var/cccamlog/cccam.check
else echo "CCcam_2.x86 is still OK!" >> /var/cccamlog/cccam.check
fi
process=`ps auxwww | grep CCcam_3.x86 | grep -v grep | awk '{print $1}'`
echo "Couldn't find CCcam_3.x86 running.removing nodeid and Restarting CCcam Server" >> /var/cccamlog/cccam.check
rm /tmp/.CCcam.nodeid && /usr/local/bin/CCcam_3.x86 -C /var/etc/CCcam_3.cfg
else echo "CCcam_3.x86 is still OK!" >> /var/cccamlog/cccam.check
fi
script name MoreCCcamstart.sh
#!/bin/bash
#Script to start more then one CCcam's with different nodeid
echo "Starting first CCcam"
echo "chown owner nodeid"
echo "Removing nodeid and starting second CCcam"
echo "Removing nodeid and starting third CCcam"
script name MoreCCcamstop
#!/bin/bash
#Script to stop all CCcam that are running.
#Script written by Youknowhoo
echo "stop first CCcam server"
killall CCcam_1.x86
echo "stop second CCcam server"
killall CCcam_2.x86
echo "stop third CCcam server"
killall CCcam_3.x86
script name MoreConfigUpdate.sh
#!/bin/bash
#Script to process new config and backup old one
#Script designed and written by CC_Share
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_1.cfg
BACKUPDIR=/var/backup
CONFIGOLD=CCcam_1.old
if test -f $SOURCE/$FILE ; then
echo "New Config Present"
if test -d $BACKUPDIR ; then
if test -f $BACKUPDIR/$CONFIGOLD ; then
echo "Removing OLD config file from backup directory"
rm $BACKUPDIR/$CONFIGOLD
else
echo "No OLD config to remove."
fi
if test -f $BACKUPDIR/$FILE ; then
echo "Renaming Backup to old config"
cp $BACKUPDIR/$FILE $BACKUPDIR/$CONFIGOLD
rm $BACKUPDIR/$FILE
else
echo "No Backupfile present yet"
fi
if test -f $TARGET/$FILE ; then
echo "Copying Original config to Backup directory"
cp $TARGET/$FILE $BACKUPDIR
rm $TARGET/$FILE
else
echo "No Original Config File Present!?!?"
fi
else
echo "Backup directory does not exist."
echo "making new directory"
mkdir $BACKUPDIR
else
fi
fi
echo "Moving New config file to "$TARGET
cp $SOURCE/$FILE $TARGET
rm $SOURCE/$FILE
else
echo "No New Config present, Nothing to process"
fi
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_2.cfg
CONFIGOLD=CCcam_2.old
else
fi
rm $BACKUPDIR/$FILE
else
fi
rm $TARGET/$FILE
else
fi
else
mkdir $BACKUPDIR
else
fi
fi
rm $SOURCE/$FILE
else
fi
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_3.cfg
CONFIGOLD=CCcam_3.old
else
fi
rm $BACKUPDIR/$FILE
else
fi
rm $TARGET/$FILE
else
fi
else
mkdir $BACKUPDIR
else
fi
fi
rm $SOURCE/$FILE
else
fi
exit
test it and don't work !!!
[Only registered and activated users can see links. Click Here To Register...]hi again,
I test your scripts and I found some error: first one is the "S" in scripts.
one other thing: the server are just starting by it self cccam_1.x86 and not the two others.
modification I do on the script to let them work on my test cccam server:
#!/bin/sh
chown root /tmp/.CCcam.nodeid
fi
fi
fi
exit
#!/bin/bash
/emu/cccam/CCcam_1.x86 -C /var/etc/CCcam_1.cfg
rm /tmp/.CCcam.nodeid && /emu/cccam/CCcam_2.x86 -C /var/etc/CCcam_2.cfg
rm /tmp/.CCcam.nodeid && /emu/cccam/CCcam_3.x86 -C /var/etc/CCcam_3.cfg
exit
#!/bin/bash
killall CCcam_1.x86
killall CCcam_2.x86
killall CCcam_3.x86
exit
#!/bin/bash
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_1.cfg
else
fi
rm $BACKUPDIR/$FILE
else
fi
rm $TARGET/$FILE
else
fi
else
mkdir $BACKUPDIR
else
fi
fi
rm $SOURCE/$FILE
else
fi
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_2.cfg
else
fi
rm $BACKUPDIR/$FILE
else
fi
rm $TARGET/$FILE
else
fi
else
mkdir $BACKUPDIR
else
fi
fi
rm $SOURCE/$FILE
else
fi
SOURCE=/var/config
TARGET=/var/etc
FILE=CCcam_3.cfg
else
fi
rm $BACKUPDIR/$FILE
else
fi
rm $TARGET/$FILE
else
fi
else
mkdir $BACKUPDIR
else
fi
fi
rm $SOURCE/$FILE
else
fi
exit
Picture of my crontab:
my rc.local:
/bin/cccam start &
/emu/script/runonce.sh &
/var/script/MoreCCcamstart.sh &
exit 0
when I tray to run cccam_2.x86 and cccam_3.86 manually I have this error:
backupserver:~# rm /tmp/.CCcam.nodeid && /emu/cccam/CCcam_2.x86 -C /var/etc/CCcam_2.cfg
rm: can't remove `/tmp/.CCcam.nodeid': no file or folder with this name
Let me know what I do wrong.
