Dreamset v2.27
Dreamset v2.27
Dreamset version 2.27 (changes)
Added: When saving from E2 two E1, all HD services are removed.
Fixed: Fix, minor parsing error in E1 & E2 settings
Fixed: Fix, set attributes to multiple services from list (popup menu)
Added: Two new options added for the setup of a connetction (Telnet usage/command). The porpose of these options are to cover the case where reload settings fail using HTTP request. You can setup whether or not you want to reload settings using a telnet command. If you do not enter a telnet command Dreamset uses for E1 "reboot" and for E2 "killall -9 enigma2"
