enigma 2 porncenter_svn_2966_r0_a
enigma2_plugin_extensions_porncenter_svn_2966_r0_all.ipk
First start:
Here is a little more complicated because the standard required for protection pin "junior", and as most of you do not set after 3 attempts to block and not have access to plugin until after 15 minutes. Do not get stuck Dream, only access to that plugin. For him to use are 2 methods:
1. Set the pin to the receiver and it will be the default plugin and pine, pine will be put every time, or:
2. Disable such protection: open file "plugin.py" and seek passage "self.pin_entered = False", it change it "self.pin_entered = True. Save the changes made, reboot emigma and ready, go. It it found in: usr/lib/enigma2/python/Plugins/Extensions/PornCenter /
What is most important, the plugin runs directly from the box without vlc or stream2dream!
