stiti unde as putea gasi un program pentru un blind scan la dm 800 sau dm 8000?
Un receptor bun la blind scan este Vantage 2xx vezi aici [Only registered and activated users can see links. Click Here To Register...]
omu cere un program si tu il trimiti sa cumpere un receptor :)
uite aici programul pe care il cauti : [Only registered and activated users can see links. Click Here To Register...]
ca si completare pt HDTV e bun-foarte bun Clarke Tech 5000 si seriile HD de la Vantage
Apropo` de blindscan, stie cineva un receptor cu blindscan si tuner Alps ?
Dupa experientele mele, cele mai bune tunere sunt cele de la Alps, si la timpul de raspuns(200 msec, La SS1) si la SR-uri(incepand de la 1000), si la stabilitate(semnal de la 25%).
Si de ce nu ai dat raspunsul mai repede :cheers:Quote:
Originally Posted by ecoke y [Only registered and activated users can see links. Click Here To Register...]
Oricum nu se compara DM la blind scan cu Vantage sau cum a spus @doktor Clarke Tech 5000.
Cu DM nu poti 'stoarce' un satelit :D.
Pe dm800 sat nu merge blindscan, nu va chinuiti degeaba,nu softul e problema ci componenta hardware adica tunerul ....doar pe
dm8000 merge cu variantele noi de tunere....
Pentru pasionatii de feed-uri , sa puteti "vana" tot ce se transmite pe satelit si receptiona toate formatele de transmisie gasiti la [Only registered and activated users can see links. Click Here To Register...]
In curand am sa-mi cumpar si eu una.:)
Prof Revolution DVB-S2 PCI 7301
· High sensitivity
· Features of reception and presentation of DVB data services (high-speed multicast and internet access)
· Support of AltDVB, [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...]
· DiSEqC 1.0, 1.1, 1.2, USALS
· Remote control
· Drivers for Windows XP/Vista/Win7
· [Only registered and activated users can see links. Click Here To Register...]
· BDA-driver (Broadcast Driver Architecture) supports many 3rd party applications
· Designed in Germany Video Features
· [Only registered and activated users can see links. Click Here To Register...] support (MPEG2 and [Only registered and activated users can see links. Click Here To Register...])
· AC3 5.1 software decoder
· Support of [Only registered and activated users can see links. Click Here To Register...] (DirectX Video Acceleration) for H.264
· Plug and play installation
· Recording and playback via TV/radio
· Teletext
· Time shift support
· Electronic Program Guide (EPG)
Additional Features
Prof DVB-S2 7301 can operate with Manna, Skynet, SkyGrabber, FastSatFinder software and different plugins for [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...], [Only registered and activated users can see links. Click Here To Register...].
Included in the Box
· DVB-card – 1 piece.
· CD with drivers and software – 1 piece.
· Remote control – 1 piece.
· External IR-receiver – 1 piece.
· Quick-start guide – 1 piece. System Requirements
· OS: Microsoft Windows 32bit 2000/XP/Vista/Win7
· CPU: 2,0 GHz
· 512MB RAM
· Sound card
· PCI-slot
· Suitable digital satellite dish System Requirements for HDTV in h.264
Video card ATI or NVIDIA:
ATI with [Only registered and activated users can see links. Click Here To Register...]: Radeon HD 5000 Series, Radeon HD 4000 Series, Radeon HD 3000 Series, Radeon HD 2600 Series, Radeon HD 2400 Series, Radeon HD 4200/AMD 785G Chipset, Radeon HD 3200/AMD 780G Chipset, Radeon HD 3300 IGP/AMD 790GX Chipset.
NVIDIA with [Only registered and activated users can see links. Click Here To Register...]: GeForce 200 Series, GeForce 9 Series, GeForce 86xx, GeForce 85xx, GeForce 84xx.
Technical Specification
8PSK/QPSK direct conversion tuner IC: [Only registered and activated users can see links. Click Here To Register...]
· Powered by RF Magic
· Direct conversion
· Input range 950 to 2150 MHz
· Supports 1 to 45 Msymbol/s
· Fully integrated LO and PLL
· Differential I/Q outputs
· Buffered XO output to clock other devices
· Low external component count
· Low power consumption
· 2-wire I2C serial interface
· 8PSK/QPSK support
· Simple interface to ST’s satellite demodulator devices
· Low phase noise, excellent linearity and LO harmonics rejection
· Small QFN-32 pin package
Multi-standard advanced demodulator: STV0903
· Multi standard demodulation
- DVBS2 QPSK, 8PSK
- Up to 45Msps DVBS, DVBS2 QPSK and 8PSK
· Technology
- 80 nm CMOS process
- Multi supply: 1.0-V core, 2.5-V analog, 3.3-V digital interfaces
- Power saving features
- LQFP128-EP 14 x 14 package, RoHS
blindscan face si echosmart-ul, cred ca orice model, si rezultatele sint destul de bune.
Da face dar foarte slab nu poti face performanta.
Stiu cum merge blind scan la echosmart naspa :D
Mai poti urca programul,ca nu mai e?Quote:
Originally Posted by ecokey [Only registered and activated users can see links. Click Here To Register...]
Am actualizat link-ul, poţi downloada acum
Uite şi o alternativă : [Only registered and activated users can see links. Click Here To Register...]
Am testat si eu prof 7500 usb mai mult pe partea de blind scan m-a dezamagit.Am incercat cu DVB viewer , alt DVB , TrasEdit merge foarte greu adaca selectezi la SR 1000-45000.
Asteptam sa apara PTG Engine 1.7 Blind scan interface cum spune aici dar de downladat canci!
Un receiver care se comporta foarte bine la blind scan este Openbox S9 HD ..cei care il detin pot confirma acest lucru...
A aparut un programel "CrazyScan" care cica face performance blind scan [Only registered and activated users can see links. Click Here To Register...]
Are cineva o placa de asta 7300 sau 7500 sa faca un test?
