Asta sa fie rezolvarea ptr softurile universale ce nu merg pe rev 3.1 ?
Originally Posted by KaonTeam
Hi all:
Many of you know we have a pending affair with the Kaon universal firmwares for NO MICOM models.
This "little" affair produces a signal loss when you scan channels in some STB's and we figure that those problematic boxes are all equipped with mainboards Rev3.x
Due the different hardware used by Kaonmedia on their products production and without any official information, schematic, diagrams, or the source code, it is very difficult for us to find a good solution, we not have access to all models for testing purposes.
For this we need your help for discover some undocumented technical information present in the main chips of ours boxes.
This link contain a test firmware (Old Emu based) with some implemented routines for debug purposes through the serial port with Hyperterminal and now this firmware will show the following information:
Code:
Device_ID: 1D405041
CUT_ID: 41
FEI_Rev: 41
DENC_CID: 80
We wait your logs for different models, especially those classic models with 12.xx.xx or 16.xx.xx hardware.
Remember also to include a note in order to indicate if the published universal firmwares work for you actually. You can attach your logs to this thread.
Thank you in advance for your interest.
Regards from Spain.
