DVR-Studio HD 1.64
DVR-Studio HD 1.64
finished the new version 1.64 of DVR-Studio HD.
IMPORTANT: This version is not yet released on the update service and therefore particularly needs to be installed.
Please an old version of the Control Panel to uninstall first and then run the MSI setup.
The following has changed in version 1.60:
New: Traffic light system for equipment selection:
For each device there is now a traffic light signal:
RED
It is not possible a movie to bring the receiver back to
YELLOW
One can bring pictures of the receiver worked well back on the same device. In the old Topfield devices used to this, the old Haeder and devices with the control files. Be retained when using the old tax files, the name of the film. Some devices are the manuals available. Please list the equipment back on the link "HS Forum use" to obtain information about.
GREEN
It is produced by Studio HD DVR all the new files that are playing for the film to the receiver is necessary. It does not matter what device was from the movie.
QUESTION MARK
Such equipment is no information available. If anyone has this device, please try other devices just once from the same manufacturer or submit us a support request for device format.
New: Enhanced support request to the Device Export:
This question is not only obtained information about the device, but also to any control files, folder structures and overall file sizes and extensions automatically recorded. In addition, a short test file to detect Haeder is generated. All this is created on the desktop as a zip file and loaded via FTP to our server.
We hope to close quickly and so fast, "white spots" on the receiver map. Wink
New: Topfield 7700HCSI / 7000 HDPVR support
New: Topfield header for old equipment
It now supports all the Topfield.
For all devices TF4000 up TF6xxx there is the export-related devices (YELLOW). This means that images of Topfied run even after cutting back on the Topfield. In addition, the new file takes only Haeder the old file.
In the TF7000 and TF7700 HDPVR HCSI also be produced, the control files, that can also be brought to these recordings STRANGE Topfield. We were able to users at exactly these two devices testing.
But there is a problem in the Tonspurauswahl and the acquisition of EPG data. This is also the reason why today is not already the version 1.65 can go online. The exported movie is already running, but even so on the Topfield.
The Topfield differ and there are 3 different handling. For the other units TF7xxx class, we now have the default han that should fit in our opinion. If you have problems, please switch to HDPVR TF7000 or TF7700 HCSI and test. Should work a different setting, please inform me. I can change instantly.
New: Comag support
New: Smart Support
New: support Ferguson
These devices have a special handling in the control files and in the follow files. This led to the summary result files when exporting to the seams were aberrations. This was caused by the Haeder, which is now being considered.
IMPORTANT: For the manufacturers, there are devices that deviate from this operation. This is also evident at the light.
New: Homecast 8100 Adjustment
At some stations there was a problem with this device, if specific data were missing in the stream.
Fix: Speed has been optimized.
The output to a file has been improved. Due to more extensive procedures, but the speed of version 1.58 no longer attainable.
Have fun with HD DVR-Studio 1.64 ....
Code:
http://rapidshare.com/files/322158549/DVR-Studio_HD_Setup164Eng.rar
Link is down , where can i download the software ?
Thanx
- [Only registered and activated users can see links. Click Here To Register...] or
